Question about Cameras
Pc does not read images from memory card
I have a promaster memory card in which the images can be retrieved on my girlfriends pc (xp) automatically. However when I try the same operations on my system (same, pc, xp) there are no images available. I get a bootex file which seems to detect the card (2gigs free space, 6 hidden files, 3 folders,954 files,1/2 gig free etc.) but no images.
I tried to directly link my cannon using their usb cable and can control the camera from the pc(web cam) but when I try to download images, the same, no images available.
Do I need to configure something in my system to receive the images? I've contacted promaster and they seem to think it's my pc not their cable or card, while contacting microsoft they could assist me for a fee, I'm using that as a last resort to solving this
Thanks for any input you might have...
  • rasvir_anjan Dec 15, 2008
    I can watch the photos on smal screen of my digital camera but same could not be obtained on my pc.
  • Cameras Master
  • 5,412 Answers
Install a USB card reader and use that
Posted on Mar 15, 2017
SOURCE: HA90 MP3/WMA player
When I was looking at this product, I contacted the manufacturer and they made it clear the unit worked best with a 512 mb or smaller card. The problem is not with Sandisk or the SD manufacturer, it is with the HA90.
Posted on Apr 18, 2007
  • 41 Answers
there might be a problem with your cord/cable (a cord/cable that will enable you to connect your cam to PC).pls try to connect the cable firmly if still does not work pls try to get your memory card from your cam and put it in a card reader. That way you may be able to download pics from your cam to your PC.
NOTE: some card readers may need an adapter to be fitted in an SD size card for example i have an micro SD memory card i will need an adapter to fit the micro SD to this picture
youll be needing this to insert it in a card reader
this is an example of an ordinary card reader
this is an example of a universal card reader
use these following devices and you will be able to download pics from your cam to PC.
i hope i was able to help you! good luck!
Posted on Nov 03, 2008
SOURCE: Web cam installation cd lost:(
i bought web cam ZSMC USB PC CAMERA (ZS211) but lost the installation cd:( Is there anyway I can install the web cam and get it working? Is there any web site from where i can download the driver
Posted on Nov 11, 2008
SOURCE: Problem Installing ZSMC USB PC Camera (ZS211)
I am trying to install ZSMC USB PC Camera (ZS211). When I tried
installing it in my Laptop (COMPAQ Presario V4000), i get message
Cannot Install this HArdware. There was a Probelm Installing this
Posted on Nov 18, 2008
SOURCE: kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Posted on Dec 28, 2008
Promaster Secure Digital Memory Card Lock
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 14, 2012 | Promaster 4GB SDHC Secure Digital Class 6...
The memory card of my Nikon S3000 can not be read. There were images I used to browse. I have not uploaded them. When I checked on it again, card could no longer be read. I try to retrieve using...
It is always ideal to transfer the images from the memory card to prevent such a failure. It is possible that the memory card has failed and so you are not able to detect on the PC. Please try the card with a different PC to confirm.
Jul 09, 2011 | Nikon Coolpix 4200 Digital Camera
I took pics with no memory card can i retrieve the pics on card ?
Please follow these steps:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
This should do the trick.
Kind regards
Aug 20, 2010 | Kodak EasyShare Z740 Digital Camera
The camera (Vivicam 3330) apparently needs a driver to retrieve images from its internal memory. Where can I find this driver? PC is running XP but I have access to other operating systems.
This camera can use an SD card up to 128mb. If you insert the card into the camera and go into the menu to find "copy", you can copy the internal memory to the card. Then, you can use a card reader to download from the card to your computer.
Aug 17, 2010 | Vivitar ViviCam 3330 Digital Camera
Saving images from S5 Pro directly to laptop hard drive -how?
Hello Brian,
Are you writing to the camera memory because your card is full?
I'm not sure what USB auto/fixed is meant to do but try this.
Connect you camera to the pc as normal and switch the camer on.
The camera may ask you if you want USB or pictbridge, choose USB.
XP Then tries to offer you the best way to get at the photos. Rather than use the transfer option us the open as a folder option.
If XP doesn't offer anything click and open my computer, look for your camera it will appear as a new hard drive.
Click on the new hard drive, normally with olympus you get a folder, the first is you camera memory, click on that you should see photo's and another folder.
Copy or cut and past the photo's to a new folder on your PC. The click on the last folder, should be you memory card, move those photo's as before.
Having copied all photos you can delete them from you camera memory and card using the PC. Just as you'd delete any file.
With luck you should be back in action, a whole card to fill................. Good Luck.
Mar 07, 2010 | Fuji FinePix S5 Pro Digital Camera
Wrong SD cards????
Your printer may have issues reading SDHC memory cards. The Secure Digital 2.0 standard (SDHC) is not backwards compatible and requires SDHC compatible devices in order to function.
Jul 08, 2009 | Epson Stylus Photo R300 InkJet Printer
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Image upload
??? These cameras take standard CF cards (and store images in standard JGP format) that can be 'read' directly by PC's with a multi-media card slot.
If your PC does not have a card slot, you can buy a USB CF Card Reader/Writer for a few dollars ..
PS always reformat the CF cards in the Camera not the PC ..
Apr 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
The memory card that has failed- do you have access to a card reader for the computer? If not we will try to use the camera. Download from www.konvar .com - PC Inspector. This is a recovery program install it and follow the prompts to locate the card in reader or camera will show on the computer a new drive. Then allow the camera to scan the card and you to select where any recovered images to go.
Sep 10, 2007 | Canon PowerShot A75 Digital Camera
Memory card format.
The Polaroid PDC 700 digital camera accommodates an optional, Type 1 ATA compatible CompactFlash memory card up to 48MB. When an unformatted memory card is installed in the camera, it is automatically formatted when the camera is powered on. WARNING: Once you format the flash memory or format a memory card, all images are erased and cannot be retrieved - they are gone forever! Before you format (erase) the flash memory or format a memory card, transfer the images to your computer.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Cameras Logo
52 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
