Question about Freezers
I have a problem with the compressor ......when i conect to the receptacle it turns on but i reset the thermostat to zero then again turn to the coldest position i does not start the compressor
Themo stat is open ciruit , try joining the wires together, if ok buy a new stat,
Posted on Nov 26, 2008
My freezer turns on when plugged in and cools to below zero, then shut off and warm to 37 degrees before turning back on. I just replaced the temperature control thermostat and the defrost thermostat.
Sounds like compressor is overheating and taking hours to restart. check by listening for the hum of the compressor shortly after it has reached temperature. also check the condenser is clean and fan working.
Dec 07, 2015 | Kenmore Freezers
Hello I have an HMCF7W1 Magic Chef freezer, after a power outage the power light comes on, but the Run light will not turn on and everything is thawed. What can I do?
Perhaps the power outage, was caused by your freezer?
When you think a reset would help, the run light should come on, after a little while. But perhaps only the thermostat is defect.
Be aware there can be so many causes, and none has to be related to the power outage, for your freezer not to work.
It would be virtually impossible to see what is wrong, from a distance. Better try to bring the food to a working fridge and call a tech to solve the problem.
Feb 08, 2015 | Magic Chef Freezers
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Refridgarator is not cooling
thermostats are usually a "on/off" switch just as a simple light switch. Ohms on a defrost timer is not very specific. It is basically a switch that turns heaters on and off while keeping the compressor off during the defrost cycle. Your thermostat may be sticking/hanging up.
Jun 04, 2017 | Maytag Freezers
I have model TFU12MOAW3 upright freezer and it does not run. I tested the voltage from the freezer control to the compressor relay and I have 120 volts. Could tell me how I can test this relay (P/N...
The relay can be tested by putting meter leads in the 2 holes on it where it attaches to the compressor and it should be closed (zero ohms of resistiance) if you have the rectangle one thats how to test it. If its older style and has the wire coils on top of it must turn it upside down but still closed w/zero ohms.
to test overload thermostat disconnect it from compressor and it to should be closed with zero ohms from spade to where wire connects to hole where it connects onto prong on compressor.
both the realy and overload should be removed from compessor to test
if both check good test compressor by one meter lead on prong where overload fits onto and other on one then the other prong. Both the start and run winding on compressor should be between 5-20 ohms if either is open compressor is dead
Gene
Aug 12, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer runs constantly,seal is okay,frost free,have tried lowering the temp,food stays frozen. zeecudaboro@tds.net
It seems to me that the thermostat is no longer sensing temperature. IT will either stay on (it controls the compressor) or wont come on at all when it becomes a problem. You can order one thru sears.com if there is not a appliance parts store nearby. To check before buying, heres what you do. You need to know the temperature (use a thermometer that reads below zero). it has to be at least 10 degrees or cooler. if it is then turn down thermostat dial to 1. if it shuts off then the thermostat is ok. if it doesnt turn off (the compressor) replace t'stat. let me know the temp. and if this works for you hope this was helpful...
Mar 30, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Danby freezer not freezer
If it is the thermostat that is defective the two wires that go to the thermostat for compressor operation can be connected together which would power up the compressor. Unplug the unit before attempting to connect the two wires. after connection is made plug it back in and if the compressor operates and the freezer comes down in temperature you definitely have a bad thermostat.
Jan 23, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer always on
If the display reads -20 even though the freezer is set for 00, shut the unit off. If you can still hear the freezer compressor running, the board has a stuck relay for the freezer compressor. You will need a new board.
Jan 20, 2008 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Freezer's power is dead
check the plug itself may be melted. next check the cord itself at terminations inside the freezer compressor section. if it's plugged into a gfci try resetting the gfci receptacle. check breaker, may have tripped off.
Aug 20, 2007 | Whirlpool 17 cu. ft. / 481 liter Upright...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
