Question about Sony KP-57WS500 57" Rear Projection Television
Samsung HCR4755W Dark colors appear red on HD content only
I have a Samsung rear projection TV:
Chassis : P62A(N)_Benhur-3
Model : HCR4755WX/XAA (HC-R4755W)
When viewing HD content from any source using the component inputs, dark colors are replaced by red. Mid-range colors, however seem to appear as intended.  SD content looks fine and does not suffer from any color issues.
I have posted pictures of the problem at:
Any help is appreciated!
Thank you
  • 308 Answers
SOURCE: Sony KP 53S65 53" rear projection TV contrast issue
While the root of the problem is likely the picture tubes aging, I'm sure it would benefit from a cleaning and adjusting. After the dust is cleaned from the lenses, the screen controls could likely be lowered to get the blacks you desire. An experienced tech would be able to do this for you.
Posted on Jan 03, 2007
SOURCE: Rear projection TV picture problem
open up the back and look at the top of the glass leans covers if they are dusty clean it
Posted on Jul 14, 2007
  • 4402 Answers
SOURCE: dark picture
sony had a recall on this set see if this is one of yours
Posted on Jan 02, 2008
  • 668 Answers
SOURCE: dull dark picture on kdf-e50a12u rear projection
Depending how long you have owned it and if a Lamp was ever replaced, it probably needs to be replaced. You can check with SONY at
1800-222-SONY and see if they could sell and send you one.
Hope this helps,
Posted on Jul 21, 2009
  • 8617 Answers
SOURCE: Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Posted on Dec 21, 2009
Testimonial: "This is by far the best response I have ever gotten on any question. Clear, concise and directed me to the source I needed to fix the problem."
I have a phillip magnavox big screen tv it works fine but the color is too dark i think i need a picture tube
If its the one indicated here or one like it :
The picture tube type (CRT) rear projection tubes require annual cleaning.
With set off and back removed locate the three large black lens atop the chassis--hard to miss them.
The are the red, green, and blue tubes and are your light source for the picture---------if dark and they are dirty or dusty the picture will be darker and not as sharp or clear as it once was..
spray some glass cleaner on a paper towel and wipe them clean.
Do not touch anything else in set and do it with set unplugged.
put back cover on and see if picture is noticeably improved; if so do it once a year or more if in a dusty place.
Let me know if you have questions.
Mar 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
Our Samsung tv will not turn on/power on. It sounds like it starts to power on, the light blinks twice then you hear something, the light stays on solid after that. This model usually has an audible tone...
I would suggest two things you need to examine :
First remove and examine the lamp to make sure it is not shattered or fractured.
Second examine the color wheel that faces the lamp (see attached photo) and if you had a fan like sound or high pitched whine before that points to the color wheel.
The color wheel is a do it your self replacement (I can help) and takes less than a hour.
Let me know what you have tried and if the lamp or color wheel are intact.
Sep 16, 2011 | Samsung HC-R4755W 47" HDTV
Comcastt HD Box indicates "Component 3 - Not supported mode"
Try HDMI if the TV has the inputs or swap the component cable.
Jul 02, 2009 | Samsung HLN5065W 50" Rear Projection...
Digital blocks appear
The HD-ILA's do not handle dark content well, it's a known problem. As far as intermittent digital blocks while viewing regular content it may be coming from your sat/cable company or you may have a problem with the digital board. I've had a few of these go bad.
Sep 23, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Samsung 52" rear projection tv convergence problem?
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
HITACHI ultrascan hd tv....
toni, you`ll need a tv tech for this problem, spark gaps need to be cleaned, crt sockets need to be cleaned and crt pins on all 3 crt`s need to be sanded, this is a common issue with this model set, good luck, BMW Rider
Dec 17, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
