Question about Hitachi 53SDX89B 53" Rear Projection Television
PROJECTION TV COLORS DEAJUSTED
THE 3 COLORS IN MY SAMSUNG ST54JPX PROJECTION IS BECOMING DEAJUSTED, AND THE AUTOMATIC ADJUSTING, IS NOT WORKING AT ALL. I HAD BEEN TRYING TO DO THE ADJUSTING MOVING THE BUTTERFLYS SCREWS BUT IS ONLY FOR THE CANONS, FOCUSING. .. APARENTLY THERE IS NOT MORE WAYS TO MOVE THE COLORS. PLEASE GIVE ME A CLUE ABOUT THIS PROBLEM , I HOPE YOU CAN HELP ME TANK YOU,,,,,,ANDREW
ctf1800
  • 4402 Answers
SOURCE: HITACHI ultrascan hd tv....
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Mar 03, 2008
  • 4234 Answers
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Either the pins on the convergence ICs need to be resoldered or the ICs need to be replaced. These are large black ICs attached to a heat sink and should be marked STKxxx. Resolder first. If that does not resolve it, replace the ICs.
Dan
Posted on Mar 17, 2008
  • 92 Answers
SOURCE: hitachi hd 57 inch rear projection tv.
You may be able to correct this problem with the convergence controls in the user menu. Hitachi also has on some projection sets a button called "magic focus" which is an automatic convergence control. If you can't seem to bring things back the way they should be you may have to get your convergence ICs replaced as well as some resistors in the convergence circuit. Unless you have above average soldering skills I'd suggest leaving that up to a technician.
Posted on Oct 07, 2008
  • 4 Answers
SOURCE: Projection TV is out of focus
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Posted on Jun 29, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi 53UWX10BA dynamic convergence works but blue is blurry
I know this set very well---you are saying convergence adjusts ok everywhere? If you understand that the blue is usually de-focused a little----there are only two ways to adjust the focus of each tube-----
1.) Behind the front speaker grill there is an inspection plate---with it removed you will see a small black plastic block with 6 controls on it; it is the MASTER SCREEN/ FOCUS BLOCK
2.) THREE of the controls left to right are Screen controls(red, green and blue) and the other 3 are FOCUS--IT IS ALL black and you need to look close to identify which is focus and which is screen---you are looking for the BLUE focus control(one of the 6)
3.) With the convergence grid on screen cover the RED and GREEN lens in the set and try to adjust the focus of the blue(I presume you know how to put the set into the Convergence mode?
4.) The only other way to adjust the Blue focus is from the back of the set---with the Red and Green lens covered up place a blanket over the top of the set that covers the whole screen--from the back of the set you will note that all three of the black focal lens have a wing nut---with the convergence grid up and only blue lines present(Green and Red lens covered with a cloth) look from behind the set at the grid---loosen the wing nut on the blue lens and slowly slide the lens left or right until the blue has the best focus possible----if it will not adjust with the focal lens or the front focus control you have a circuit problem.
I do this here for free and if this information helps you take a minute and give me a vote here. If you have any questions or need advice reply to this posting here and I will assist you.
SD TECH
Posted on Sep 15, 2009
Testimonial: "Thank You! Much better quality now! Your advice was dead on. I did not think it was convergence problem....One more Q, where do I send the beer?"
Our samsung HCl4715W tv is all connected right but our picture is scrambled where you see double exposure and the color is off. Can not find our manual. any suggestions?
The problem of your tv is the convergence. Projection tv set has a 3 colors red,blue and green this 3 colors must be properly lined up to look the video normal. When this 3 colors is not properly aligned the video will produce a double image of color or like a 3d or wavy. In order to fix this problem you should adjust it in the menu program of your tv you should move any of the colors to up or down, left or right if you cannot align the 3 colors the problem is the convergence ic it must be replace. To locate the convergence ic you should remove the back cover of your tv but be sure to unplug your tv, you will see this ic attached in a large aluminum plate it has a marking of stk--- and followed by a numbers. or you could contact a service technician do do it for you and save you from stress. Good day and best regards.
Jul 17, 2011 | Samsung HCL4715W 47" Rear Projection...
3 colored lines small picture
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The color is bad on my projection television, I want to know how to adjust the lens.
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 15, 2011 | Samsung HCL473W 47" Rear Projection...
My samsung HCM4216W TV has 3-D effect i was told it is a conversion module for the bulbs is this right
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 12, 2011 | Samsung HCM4216W 42" Rear Projection...
Colors look like 3-D
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 05, 2010 | Hitachi 46F500 46" Rear Projection...
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My 52
YOU NEED TO REPLACE THE CONVERGENCE OUTPUT I.C.
Dec 26, 2009 | RCA P52926 52" Rear Projection Television
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Color problem with the samsung 46" PCK520R TV
There are a few possible causes for this
-Picture tube has become weak after long useage
-A fault with the automatic degauss circuit could be causing the color problems.
-The color drive circuits may be out of adjustment.
I don't have instructions for you on how to fix this, I would recommend you either buy premium assistance or contact
another expert with long tv experience to possibly get details
on how to correct this problem.
I would recommend you contact your dealer for repairs if you have warranty. If you don't have warranty it may be cheaper to ask around.
Jun 09, 2008 | Samsung PCK5315RX TV
Yellowish color
turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Aug 26, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 53SDX89B 53" Rear Projection Television Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
