Question about Lexmark Office Equipment & Supplies
Select cartridge Installed - has frozen - Lexmark Office Equipment & Supplies
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Hello lstr8493,
Can you described exactly what you did and what you are seeing?
- Vincent
Posted on Nov 22, 2008
Will replacing a cartridge in my Jado Glance single lever bathroom faucet make the water flow again? It's down to a trickle!
Sounds like you installed the cartridge incorrectly. The orientation is important to note when removing the old unit. Try pulling it out and reversing the orientation. Check the inlets and match them up.
Dec 18, 2014 | Jado Plumbing
Xerox phaser 6140
Hi Anonymous,
I suspect you should have this problem sorted by now.
Looking at the Xerox website says that a replacement printer is available for around £190 that could have worked out cheaper that trying to get this one repaired.
Replacement Xerox 6500
Good Luck.
Jun 17, 2014 | Xerox Phaser Office Equipment & Supplies
I installed a new black cartridge and my L7780 is still telling me to replace the empty ink cartridge
You may want to try the clean the printhead:
  1. Press the Setup button.
  2. Select Tools.
  3. Select Clean Printhead.
Oct 29, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
How do you install cartridge in z82 printer
To install the cartridges, please follow the steps given below:
1. Press "Setup" until "Cartridge" appears on the display.
2. Press the "Right arrow" button until "Change cartridge" appears on the second row of the display.
3. Press "Enter/Select." Now you may install the cartridges in the cartridge carrier.
4. Press "Right arrow" to select the color cartridge type that you installed, once "Left Cartridge?" appears on the display.
5. Press "Enter/Select."
6. Press "Right arrow" to select the black cartridge type that you installed, once "Right Cartridge?" appears in the display.
7. Press "Enter/Select."
An alignment test page should print if "New Cartridge" is selected.
From
Jeethu
Sep 15, 2010 | Lexmark Color Z82 InkJet
Can't get cold water
the balancing spool sounds like it is frozen. You need to replace the cartridge. The spool needs to move freely to regulate the water coming through it to keep from scalding a person.
Nov 20, 2009 | Moen Posi-Temp Single HandleTub And Shower...
I need to know how to get to the ink cartridges on
  1. Make sure the All-In-One is on.
  2. Pull the control panel toward you, and then open the cartridge access door
The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy.
  1. Pull the old cartridges toward you, and then lift them out. Store them in an air tight container or dispose of them.
If you are installing new cartridges, remove the sticker and transparent tape from the bottom of the cartridges.
Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
Push back firmly on the cartridges until they snap securely into place.
Close the cartridge access door, and then close the control panel.
  1. Use the buttons on the control panel to answer the questions that appear on the display:
  2. If the color cartridge you installed is new (it has never been used), press Select.
If it is old (it has been used), press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the color cartridge you are using, press Select.
If it is not the number of the color cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. If the black cartridge you installed is new, press Select.
If it is old, press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the black cartridge you are using, press Select.
If it is not the number of the black cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. Continue with Aligning the print cartridges to ensure proper installation.
Note: You can also use the Lexmark Solution Center to install the print cartridges
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Lexmark Solution Center.
  • From the All-In-One Center, click the Maintain/Troubleshoot tab, and then click on a topic.
    Here is the manual
    Hope that helps you :)
Nov 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x85 multifunctional, not recognize cartidrige color
The cartridges are only installed through the printer itself and there is no installation of cartridges through the Lexmark software. You should ensure the Lexmark X85 has the cartridges installed in stand-alone mode. To do so, please follow the steps given below:
1. Push the "Menu" button 10 times, until "Maintenance" appears.
2. Then hit "Select" and "Change Cartridges" should appear.
3. Hit "Select" again. It will prompt you to open the lid and change the cartridges. Please do so.
4. When the lid is closed, the display will ask you if new or old cartridges were installed. If new, it may ask you to align the cartridges and you should do this too.
If it is not noticing a change, remove and reinsert the cartridges about 3 times in a row to re-establish pin connections. If this still presents you with a "Change Cartridge" or "Low Ink Level" message or something similar, try a different cartridge.
Oct 17, 2009 | Lexmark X85 All-In-One InkJet Printer
Expson CX8400 All-in-one printer
I had a problem with one of my Epson ink cartriges and called the company and they replaced it for free. Also many companies that sell knock off ink cartridges now have fixed the problem and now they are recognized by the printer.
Jul 11, 2008 | Epson CX8400 All-In-One InkJet Printer
Lexmark 5150 - Error 0502
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Jan 07, 2008 | Lexmark X5250 All-In-One InkJet Printer
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
