Question about Kenmore 62602 Electric Dryer
Dryer wont heat
Whirlpool dryer (le5800xsw3) replced heating element still no heat, dryer works-blows ectr. just stoped heating one day. what to do next?
  • Anonymous Mar 14, 2014
    Dryer is spinning but only blowing cold air. Where is the element located?
  • Kenmore Master
  • 3,463 Answers
Hi.
Check thermostat Make sure you are getting power to the element and stat.
If not , then timer probably faulty
Posted on Nov 22, 2008
I recently had the heating element replaced on my whirlpool electric dryer model #LE5800XSW3. Prior to replacement, clothes dried completely in one cycle. After replacement the clothes take at least two...
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Jan 22, 2011 | Whirlpool Dryers
My worldpool dryer truns but will not heat up??
Thank you for contacting Fixya.com.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Check the thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) that is mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation.
Please check the bellow link to have an in-depth knowledge as to when the dryer wont heat up...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have any further query.
Have a nice day.
Nov 29, 2010 | Whirlpool Dryers
MY dryer stoped working
I need your model number to be more helpful. You can start by checking your door switch if the dryer just won't start. You should hear a click from the door switch when you open or close it. If no sound then replace the switch. If the dryer runs, but no heat, often a dryers heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a video to help you check for the problem.
Nov 26, 2010 | Whirlpool Dryers
I don't know anything about dryers so please bear with me. My dryer drum turns, fan blows, but wont heat. replaced heating element. Still no heat. Has 124 volts on both prongs of element. What should i do?...
Have you tried flipping the breakers @ your electrical box? Mine will do that at time when one breaker has tripped. It will have enough juice to run it but not heat it. IF that doesn't work there may be a broken wire to the heating element or possibly even a faulty heating element. I'd try the breakers first though.(Im not a professional I've just been a single mom for 18 years and have found myself working on all sorts of things and gaining knowledge from hands on experience) Hope it helps & works.
Aug 03, 2010 | Whirlpool Dryers
Whirlpool dryer
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse which is about an inch long is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Thank you !!
Jun 21, 2010 | Whirlpool LER4634J Electric Dryer
Dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Mar 02, 2010 | Whirlpool Dryers
Wont start up, just replaced the heating coil and it worked fine for a few days, now dryer wont start
check your wires and fuses next to the heating element. first one i would check is the white plastic one. that is a non resetable fuse.
Dec 11, 2009 | Whirlpool LEB6300 Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Kenmore 62602 Electric Dryer Logo
264 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
