Question about Texas Instruments TI-Nspire Graphic Calculator
Won't boot into new screen
Ilocked up my Nspire-84 keypad by running Doors CS and trying to run aprogram (which made a error) and clicking 2: go to error. It thenshowed up with a error screen. The problem is I can't do anything atall, and when i take the keypad out, and even replace the batteries, Itboots into that screen, leaving the keypad useless.
I seriously need help because i need the TI-84 keypad for school.
  • agsgymboy Nov 22, 2008
    SWEET! I FIGURED IT OUT! JUST PRESS THE RESET BUTTON ON THE BACK! It just deletes all your apps, ram, rom, etc. Works.
  • 4 Answers
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Hold down [Home] [Enter] [P], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Posted on Jan 30, 2009
Os transferring error
The standalone version of the OS for the TI84Plus/TI84Plus SE are not for TI-Nspire with TI84 keyboard. The 94 Plus part of the TI-Nspire is updated when you update the OS of the TI-Nspire. The version numbers are different.
To update you TI84 portion of the TI-Nspire, update the OS for the TI-Nspire. Thy are now at Version 3.2.3.1233
Sep 26, 2013 | Texas Instruments TI-84 Plus Silver...
Ti-nspire with 84 keypad problems
It seems to me that you get the loading bar when you switch keypads. I just switched keypads, and when I reinserted the TI84 Plus keypad back again I found my last TI84 Plus screen contents still displayed.
As to the RAM cleared message, it probably is related to the batteries being depleted.
To verify battery charge level, you may use TI connect.
Mar 31, 2012 | Texas Instruments TI-Nspire Graphic...
How do you put the batteries in?
  2. Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press [On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc] [Enter] [EE], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at the top right of the TI-Nspire keypad and has a picture of a house on it.
Aug 26, 2011 | Texas Instruments TI-83 Plus Calculator
I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
Mar 12, 2010 | Texas Instruments TI-Nspire Graphic...
TI-Nspire 84 Plus keypad problem
Remove the TI84 Keyboard, insert the TI-Nspire keyboard and try to reset the calculator with a starightened paper clip.Calculator has a reset button on the back.
Jan 23, 2010 | Texas Instruments TI-Nspire Graphic...
Ti 84 nspire,replaced batteries and now it says "operating system not found,install OS" Of course my son has a finals exam tomorrow..help!!
Hi
A. Download the TINspire OS from education.ti.com
Use the Ti-Nspire computer link to reload the OS onto the calculator.
  1. Remove the Ti84 keyboard and insert the Ti-Nspire keyboard.
  2. Make sure the battery are good.
  3. Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable
  4. Run the Ti-Nspire computer link software.
  5. The select device dialog should appear, and detect the device.
  6. With the mouse cursor, select the OS, drag it and drop it on the main window (file browser window) of the TI-Nspire computer link software.
  7. Alternatively, click the menu Tools and select Install OS. A Select file window opens.Use the browse button to point to the OS and click Open/OK
B Installing from another Ti-Nspire ( not a TI-Nspire CAS) if availabe)
  1. Connect the two devices using the USB Mini A to Mini B cable
  2. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
  3. Both units must be turned ON
  4. On the sending unit, access the document chooser by pressing [Home](the house icon).
  5. Once in the document chooser, press [Menu] and choose 9:Send OS…
Hope it helps.
Thank you for rating the solution.
Dec 11, 2009 | Texas Instruments TI-84 Plus Calculator
TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Nov 23, 2009 | Texas Instruments TI-Nspire Graphic...
Havent used my ti-inspire since last school year.wont turn on
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Hope it helps you solve the problem.
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
TI 83 TI 84 and TI Nspire
Yes, the Ti nspire not only functions as a ti83 but, also operate w/ nice advance math software that any teacher would envey. It comes with the ti83 keypad plus software and great instructions to help the instructor at all levels of math learning. I don't know any better and it is a beautiful plan that ti has set up.
Apr 03, 2009 | Texas Instruments TI-84 Plus Calculator
Loading Screen Freeze
  1. Remove the keypad (for TI-Nspire) or the battery door (forTI-Nspire CAS) and remove at least 1 battery from each column ofbatteries. After 2-5 seconds, reinsert the batteries and turn the uniton. This will cause the unit to reboot the operating system.
  2. Holddown [Home] [Enter] [P], and while holding these keys, press [On]. Thedevice will boot up as in the previous reset, but will display a menuwith the following options. Please try options 2, 3, and 4 in thatorder.
Dec 21, 2008 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-Nspire Graphic Calculator Logo
779 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
