Question about Philips DVDR3455H/37B
DVD drive will no longer open
When I press open, I get the message "Blocked...Closing." I unplugged the unit and left it unplugged for a day. No change. I moved the plastice piece below the dvd drive on the unit to the left to make sure the drive could be opened. It did open. I then closed it back ensuring the plastic piece was back to the right. However, when powering the unit back on, I continue to get the same message.
  • miriamc14 Dec 31, 2008
    I have the same problem and also noticed that can not operate any of the buttons in the front of de dvdr. There is one dvd inside but can´t take it out
I went to look at getting it fixed and wit was going to cost as much as a new device, so I pulled it to bits and found that the rubber band in the DVD player was frail. This meant it didn't have enough strenght to load the disk completely.
I went to a stationary shop and brought a new one the same size and it is perfect.
Cost. 10c.
You will need to be careful and confident pulling it to bits and some of the screws are no standard. good luck.
Alternatively there is a slot under the unit that you can force the DVD mechanism open or closed. A hassle though.
Posted on Mar 15, 2009
I have 2 of these units and both have the same problem. I found that when I keep a DVD in the tray I never have the problem. If I forget to leave a DVD in the tray, the unit will not open and I get the message. I guess that the tray must get stuck on something inside the unit and when a DVD is left in the tray it prevents the tray from sticking. I always use an old DVD or for that matter even a CD
Posted on Dec 05, 2008
  • 3 Answers
Look at this:
http://forum.videohelp.com/threads/311434-I-fixed-my-Philips-DVDR-3455H-dvd-hdd-recorder
down the pdf by Imonfa, answer 17
he is an expert!!!
To get the dvd, open the tray manually, follow the instruccions by the service manual
pag 6, picture 4.1
http://www.zshare.net/download/824070401c355e7d/
good luck!
Posted on Nov 06, 2010
My CDROM drive keeps opening and closing randomly. I have tried disabling it in Device Mgr, but it still is opening and closing. I also uninstalled it in Device Mgr, but still it won't stop opening and...
Do you actually use the CDROM drive?
I assume no because you say you keep trying to disable/uninstall it- If this is the case, just unplug the power cord from the back of the drive.
Only thing I can think of that would cause this is a faulty/intermittent connection inside the CD Drive, which could only feasibly be fixed by replacing it. They're like $12 these days.
Jan 11, 2011 | Artec WSM-52X-UR CD-RW Burner
Inserted a dvd - the dvd could not be read for whatever reason. tried to take the dvd out - drive will not open. all it says is opening. I press eject again and it says closing. press eject says opening....
Sounds like your load belt is slipping. Unplug and remove the case. You should be able to see the belt (you may have to remove the cd first). Some are easy to change and others can be a nightmare. If yours is the latter you need to make absolutely sure you know where everything goes before removing anything as the timing of the unit is critical. Belts can be purchased at www.mcmelectronics.com Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 19, 2010 | Bose 3 2 1 GSX System
Disc tray keeps opening/closing on DVD recorder
my dvd player sony cinema entertainment system dav-dz111 the tray is opening again after closing
Sep 22, 2009 | Televison & Video
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
MY DVDR3380 TRAY WILL NOT OPEN, SAYS ITS BLOCKED
I had the same "Blocked" problem and solved it - by using a rubber band! Unplug the machine and take off the outer cover. Remove the DVD reader and take off the cover to the reader - you can now easily recover the DVD that was stuck in the machine. Now slide out the actual DVD tray, you will have to bend back a couple of restraining bars to get the tray out completely. You should now see a small white wheel which is actually the end of a concealed electric motor. There will also be a larger black pulley which controls the movement of the DVD tray. If there is no band connecting the pulley and the white wheel, that is your problem and I solved it with a small elastic band. Put everything back and turn on, wait for all the messages to clear and press the eject button - the tray opens simples. It has taught me never to force the tray in manually, but to always use the eject/open button.
Aug 22, 2009 | Philips Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Philips DVDR 3390/37
Hi. Look underneath (bottom) of unit, right under the DVD drive. There is a open narrow slot. Take a PLASTIC, or non-metal, instument, like a chop-stick, etc., & insert into slot. Start from the very right of open slot & move the instrument to the left. You will be moving a plastic slider that will open the dvd drive, Simple. Also, keep a dummy disc in drive & it will open all the time, but the drive will constantly spin & spin, overheat & no longer work. It only shuts down when no disc is inserted. I have rebuilt dozens of these models. What I do is after viewing disc, I remove right away, because when you switch to view from hdd or cable/sat., the inserted disc will spin all the time & wear out drive very soon. By keeping a disc out, the drive will last a long time. It is so easy just to manually!! open the dvd drive, each time. Better than replacing with a PC internal IDE dvd burner. Then you have to cut hole on top for IDE cable & power cable & the dvd burner/drive sits on top of unit because it will NOT fit inside. Plus, if you do this, remember to put plastic button on master slot seen on the back of new dvd burner. Also, another tip, if you save a show, ect, on HDD, burn onto disc right away, if you want to save program onto a disc. Another tip, you can hold onto stop button on remote, a few seconds, & dvd drive door will open. Hold again & it will shut.
Aug 07, 2007 | Philips DVDR3390/37 DVD Recorder
DVD/Video recorder blinking
This is an issue for this machine. It happened to me, and after some internet research, I found that JVC acknowleged it (on their web site). The unit was still under warranty, and JVC had me ship it to them for repair. It was fixed... for about a year. It started doing the same thing recently. I only had enough time to discover that I hadn't purchased any extended warranty, then the thing quit altogether. Wouldn't even power up, wouldn't eject the tape or DVD that were inside. I gave up, and took the case off to recover the tape and DVD. What I found inside was what looked like any DVD or CD drive from any computer. Since I had a case for an external IDE drive, I hooked it up to my Mac using that drive. Good news! Not only did it eject my DVD when I pushed the button, I found that my Mac with OS X Tiger recognized the drive! With absolutely NO software installation (not even a driver), My Mac now burns DVDs beautifully on that drive using Toast. At least I salvaged something really good from that piece of junk sold by JVC.
Apr 28, 2007 | JVC DR-MV1S DVD Recorder/VCR
DVD message says "blocked"
some one had enterd a code into your system causeing that problem if you do not remember the code you will have to take it to a techn in order that they lift off the chip and reset it all over.
Jan 27, 2007 | Philips Magnavox MDV530R DVD VCR
PD-DVR100 DVD Tray will not open
Hi Mikey We are having the exact same problem with our recorder. Don't know if it will work for you, but we turned it off and while it was saying hello, my husband kept pushing the open button and it finally opened. We recorded a movie last nite, and it wont do anything, just keeps flashing PrOce on the player screen. I called the 800 number and he told me to unplug it too, that it would reset itself. It's pretty bad when you spend $300 on something and it only has a 90 day warranty, and then they expect you to just take it to a repair place and have it fixed yourself. We will never buy a Protron product ever again. Guess we just have to go buy a new one, since they wont help on this one. If anyone else has any suggestions, please help us out. Thanks, Becnfiat
Jan 02, 2007 | Protron PD-DVR100 DVD Recorder
Philips DVDR3455H/37B Logo
659 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
