Question about Acer Computers & Internet
How do I replace the optical drive on a acer 3690-2672 ?
  • 849 Answers
See at bottom a screw must be there, un-tied it, pull the drive, the drive will come out, replace with new one.
Posted on Nov 22, 2008
Removing cd rom
The optical (CD) drive on your Acer laptop connects to the side of the device and is accessed via the underside of the computer.
If you are having problems with the optical drive on your laptop you should address it as soon as possible, and one thing you may need to do is remove it.
The good news is that even if you aren't particularly tech savvy, you'll find that the process of removing and replacing your optical drive is relatively easy.
Turn your Acer off and remove any power cables that may be attached to the side of the unit. Turn your Acer upside down.
Slide the battery out of its compartment on the underside of the computer.
Locate the circular optical drive retaining screw on the underside of your laptop.
It is located just above the square WiFi compartment in the middle of the computer.
Use your Phillips screwdriver to remove the screw and set it aside.
Grip the optical drive by its edge on the side of the computer and gently pull to remove it from the computer.
Slide a new optical drive into the computer, making sure the disk opening is facing out of the laptop.
Replace the optical drive screw.
Replace the CD Drive on an Acer Aspire 5000
The CD drive of the Acer Aspire 5000 is designed like most other laptop optical drives.
The CD drive is on the right-hand side of the computer and is attached with screws from the back of the case.
All you need to complete the task is a screwdriver.
To avoid electric shock or damage to the laptop, always ground your tools by touching them against a metal object like a table leg before using them on the computer.
Turn the Acer Aspire 5000 laptop off.
Unplug the power cord from the electrical outlet. Remove the power cord from the power supply in the side of the laptop.
Flip the laptop over so you are looking at the bottom of the case.
Slide the battery pack off the top of the case.
You'll see the CD drive on the left-hand side of the laptop when you are looking at the bottom of the case.
Unfasten the screws that are holding the CD drive onto the laptop with a screwdriver. Slide the drive out of the case.
Slide the new CD drive into the case and secure it with the screws.
Place the battery pack in the laptop and turn the computer back over so it is sitting on its base. Plug the power cord into the power supply in the side of the laptop.
Plug the other end of the cord into the electrical outlet.
Sep 06, 2013 | Acer Aspire 5610-4648 Notebook
Acer aspire 7741z optical drive not reading
Try Using a cleaning disc in the drive. If still not working, drive broken, replace.
Sep 05, 2012 | Acer Aspire 7741z
When I put a cd or dvd in the drive computer does not recognise there is a drive at all it is an acer 5315
consider to replace your dvd rom, because maybe it caused the dvd or cd cant read the cd or your dvd, maybe it caused the optic (head) of your optical drive is weak because of thr dust or dirty, before you replace your optical drive you can try to clean the optic using dvd or cd cleaner
Jan 16, 2011 | Acer Aspire 5315 Notebook
How do i remove the optical drive from my Acer AS7736z4015 laptop?
Usually there is a screw or two on the bottom of the notebook holding the optical drive in place. If you unscrew these screws, eject the optical drive's door & pull it outwards (of course while the notebook is switched off, unplugged & the battery removed, you will be able to remove the optical drive out of its bay.
Oct 31, 2010 | Acer AS7736Z4015 Notebook
Optical drive will tray will not close
They are easy but expensive to replace from the vendor.
Options: 1 - Live with the problem 2 -Source a replacement Drive on eBay 3 - Contact the vender for a repair. This will be expensive. 4 - Purchase a USB external drive
Dec 06, 2009 | Acer Aspire 5735 Notebook
Replace the optical drive on Acer Aspire m1201
based on the images i've looked on for the Aspire m1201, you don't need to remove the front panel in order to remove the optical drive. if there are screws holding the drive in, remove them and then slide the drive forward. if its held in by sliding latches and not screws, then slide then in which ever direction necessary and then push the drive forward to take it out.
Sep 23, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
I have an Acer Travelmate 4670 and want to replace a defective optical drive (DVD/CD RW). Where can I get a replacement drive?
Chach at any local Acer spares shop. Ususally the drives are available with most computer parts vendors. In you have no luck call Acer and order it from theire sales department.
Aug 13, 2009 | Acer TravelMate TM4672WLMi Notebook
Optical drive problem
The optical drive needs to be replaced.
Jun 14, 2009 | Acer Computers & Internet
CD drive not working
Can you try if the CD/DVD optical drive can boot from a windows cd - if so your problem is probably windows software if not drive optics may need cleaning or it may be necessary to replace the drive. If replacement is necessary it is the fitting of the front bezel - to the same type of drive [usually the same manufacturer] that is critical.
Mar 14, 2008 | Acer Aspire 5610-4648 Notebook
Removing old/Installing new optical drive?
hi chris, best thing is to get hold of a manual but since NEC's support is not that good they don't provide them on their websites for download. but not to worry, generally you got 2 options from my experience i can confirm that the first one is the old drive is secured with a screw located in the back of the laptop underneath the drive itself if that's the case just unscrew it and release the old drive , the other option is you might need to strip the laptop down and unscrew the drive from inside the laptop i guarantee you these are the only ways manufacturers secure optical drives to laptops. hope this helps
Aug 19, 2007 | Acer Aspire 5003WLMi Notebook
Computers & Internet Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
