Question about Microsoft Windows Server Standard 2003 for PC
Internate sharing close in day maximum 5 time or more
I have server 2003sp1 and on load extra setup sp2.in server broadband service for internate. with join in total 16pc.now server in to 2lancard 1)lancard in broadband service 2)lancard in local network. so my problem is sharing disconnect on server and all client total internate service close but in the server continue net not a close net.so please resolve help me
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    I think you have:
    1 Server2003 with SP2
    16 pc on the LAN (WinXP i sopose)
    That you have two (2) NIC in your Server,
    and - that you want to block your users (16 pc) from access the internet....
    - is this the case???????
    Re-write your problem, Im not sure that I understand
    /Teis
Nothing Put ur Client PC' s Default gate. And then DNS IP- Address as server's ip-Address.I thing this method may be already configured on ur Server. Not yet, Try it Now......
Posted on Dec 10, 2008
How do I secure?
WIRELESS To configure the Router as a wireless access point for wireless clients (either stationary or roaming), all you need to do is define the radio channel, the Service Set identifier (SSID), and security options.ADVANCED SETUP 47 Channel and SSID You must specify a common radio channel and SSID (Service Set ID) to be used by the Router and all of your wireless clients. Be sure you configure all of your clients to the same values. SSID: The Service Set ID. This should be set to the same value as the other wireless devices in your network. SSID Broadcast: Broadcasting the SSID on the wireless network for easy connection with client PCs. For security reasons, you should disable SSID broadcast. (Default: Enable) Note: The SSID is case sensitive and can consist of up to 32 alphanumeric characters. Wireless Mode: Set the communication mode for the Router. Default: Mixed (11b+11g)Configuring the Wireless Barricade g Router 48 Transmission Rate: Set the rate of data transmitted from the Router. The lower the data rate, the longer the transmission distance. (Default: Fully Automatic.) Channel: The radio channel through which the Router communicates with PCs in its BSS. (Default: 6) Note: The available channel settings are limited by local regulations. g Nitro: In a crowded 2.4 MHz frequency, the connection speed is much lower than the promised 54 Mbps. The g Nitro implemented by Intersil's Prism Nitro technology dramatically enhances your wireless network speeds. It provides up to 50% more throughput in 11g only environment, and improves network throughput by 3 times in mixed mode.ADVANCED SETUP 49 Security If you are transmitting sensitive data across radio channels, you should enable wireless security. Configuring the Wireless Barricade g Router 50 WEP Wired Equivalent Privacy (WEP) encryption requires you to use the same set of encryption/decryption keys for the Router and all of your wireless clients. WEP mode: You can choose disabled, 64-bit or 128-bit encryption. Key Provisioning: Select a key type of static key or dynamic key. Static WEP Key Setting You may manually enter the keys or automatically generate encryption keys. To manually configure the keys, enter 10 digits for each 64-bit key, or enter 26 digits for the single 128-bit key. (A hexadecimal digit is a number or letter in the range 0-9 or A-F.) For automatic 64-bit security, check the box of Passphrase, enter a passphrase and click SAVE SETTINGS. ADVANCED SETUP 51 Four keys will be generated. Choose a key ID (1-4) from the drop-down list or accept the default key. If you use encryption, configure the same keys used for the Router on each of your wireless clients. Note that Wired Equivalent Privacy (WEP) protects data transmitted between wireless nodes, but does not protect any transmissions over your wired network or over the Internet. WPA Wi-Fi Protected Access (WPA) combines Temporal Key Integrity Protocol (TKIP) and 802.1x mechanisms. It provides dynamic key encryption and 802.1x authentication service. With TKIP, WPA uses 48-bit initialization vectors, calculates an 8-byte message integrity code, and generates an encryption key periodically. For authentication, it allows you to use 802.1x authentication for an environment with a RADIUS server installed on your network. Selecting the Pre-shared Key enables WPA to use the pre-shared key in a SOHO network.Configuring the Wireless Barricade g Router 52 Field Default Parameter Description Cypher suite TKIP One of the security mechanism used by WPA for frame body and CRC frame encryption Authentication 802.1X Select the authentication mode. • 802.1X: It is for an enterprise network with a RADIUS server installed. • Pre-shared Key: It is for a SOHO network without any authentication server installed. Pre-shared key type Passphrase (8~63 characters) Select the key type as in pass-phrase or in 64-Hex characters Pre-shared Key none Specify in pass-phrase style or in 64-Hex characters. Group Key Re_Keying Disable The period of renewing broadcast/ multicast keyADVANCED SETUP 53 802.1X Management access will be checked against the authentication database stored on the Router. If an authentication RADIUS server is used, you must specify the secret key of the Message-Authenticator attribute, i.e., Message Digest-5 (MD5), and the corresponding parameters in the RADIUS Server Parameters field for the remote authentication protocol.Configuring the Wireless Barricade g Router 54 • General Parameters • RADIUS Server Parameters Field Default Parameter Description Enable 802.1X Yes Starts using 802.1x security control. Session Idle Timeout 300 seconds Defines a maximum period of time for which the connection is maintained during inactivity. Re-Authentication Period 3600 seconds Defines a maximum period of time for which the RADIUS server will dynamically re-assign a session key to a connected client station. Quiet Period 60 seconds Defines a maximum period of time for which the Router will wait between failed authentications. Server Type RADIUS Selects the authentication server type. Field Defaults Description Server IP 192.168.1.1 The IP address of the RADIUS server. Server Port 1812 UDP port is used for RADIUS authentication messages. Secret Key none Defines a text string on both the RADIUS client and server to secure RADIUS traffic. The RADIUS server requires MD5 Message-Authenticator attribute for all access request messages. The 802.1x authentication scheme is supported by using the Extensible Authentication Protocol (EAP) over the RADIUS server. NAS-ID none Defines the request identifier of the Network Access Server
Source: http://www.smc.com/files/AK/2804WBRP-G_MN.pdf
Please leave feedback for this answer, thanks.
Mar 10, 2011 | SMC Barricade g SMC2804WBRP-G Wireless...
Tip
Check your broadband speed and report it as a Slow/Not Spot
I have a maximum download (connection) speed of 3.5MB at my exchange which is a Local Loop Unbundling or LLU from which I live about 5km as the crow files.
My expected maximum will be only 70% of this at about 2.5MB due to signal to noise ratio loss on the BT line, dont bother trying to change your MTU or any TCP tweak settings you will probably cause more problems with the speed becoming lower maybe even cutting yourself off your own broadband connection
However most ISP use Local Loop Unbundling is the process by which third party networkoperators are able to install equipment in to BT telephone exchanges in order to provide their own services without having to touch BT's network. Only the copper pair from the exchange to the premises, which remains the property of BT, is used by the third party. Use SamKnowsBest to check what options you have at your local BT exchange
BT copper line MAX is only 8MB irrespective of the the LLU that you use this means your ISP hardware.
Optical Cables MAX is 20MB and only Virgin Media in the UK can use this transmission medium.
I used to get only 750kbps which is not even 1MB now I can get double that between about 1500kbps - 1800kbps which is still only 1.8MB depending upon the time of day.
Also make sure that your connection is not shared with another user they will steal your bandwidth ensure that if you are using wireless use a WEP or even better a WPA-PSK encryption. Close all instances of P2P or FTP uploading during the speed test.
http://www.speed.io/index_en.html
My Results as a comparision
http://speed.io/backend/result/24801225?pID=project1 750 Kbps
http://speed.io/backend/result/27957779?pID=project1 1500 Kbps
http://speed.io/backend/result/27959284?pID=project1 1800 Kbps
There is not a lot you can do other than report this slow speed to this website the more they can build up a picture of the bad or NOT SPOT areas then your ISP will have to act to ensure that you don't move your service to another provider.
http://www.broadband-notspot.org.uk/
NOTE:
If you have the same problem as me then unless you can get Virgin Media Cable that can supply upto 20MB download speeds then BT maximum 8MB speed will be your limit expect to get about 4MB using the BT copper wired pair and your ISP's own router if you live over 5 miles from the exchange.
on Jan 05, 2010 | Computers & Internet
I WANT TO INSTALL 2003 SERVER ON IBM X236 BUT IT IS SHOWING NO DRIVE PRESENT
Use the IBM configuration disk and it should be able to prepare the server for what ever OS you need to install. If you don't have it then, try redoing RAID and reformat the hard drives and try again..You can probably hit F6 during the initial portion of the install and supply the necessary SATA drivers on a floppy and get it to install. You will probably need a USB floppy though unless your server has a floppy drive.
Insert your Microsoft Server 2003 Installation disc into the CD/DVD-ROM drive and boot the server from the installation disc. Microsoft Setup will load the files it needs to perform an installation. Press "Enter" to setup and install Windows.
  • 2 Press "F8" to accept the Microsoft License Agreement.
  • 3 Create a new partition to install the operating system onto by selecting the "Unpartitioned Space" and pressing "C." If there is no unpartitioned space, highlight and delete all of the other partitions on the hard drive by pressing "D." Set the partition size to the "Maximum Size" and press "Enter."
  • 4 Format your new partition with the "NTFS" or the "NTFS (Quick)" option. Windows setup will format your hard drive and load the installation files. Your IBM Netfinity will restart and installation will continue.
  • 5 Select language and regional setup information, then press "Next." Enter your name and company name, then press "Next." Enter your Windows 2003 Server Product Key and press "Next."
  • 6 Select the licensing mode you would prefer to use and press "Next." Create an administrative account and password and press "Next." Enter the current time and time zone and press "Next."
  • 7 Setup your Network information by naming the server and defining how it will connect through the net. Press "Next" to navigate through the network setup screens. Windows Setup will finish the installation process and provide you with a log-in screen to use your computer.
  • If you delete old partitions from the hard drive to install Windows Server 2003, you will lose all information on those partitions.
    Jan 20, 2011 | IBM eServer xSeries 236
    I need service pack 2 for windows xp but all microsoft sites say "server not found" or "page unavailable"
    Please follow the steps to download win xp sp2
    (1) click on the link to go on downlad website
    (2) on the download button on this website click download.
    (3) Save the service pack in your computer harddrive.
    (4) run sp2 setup when download complete.
    (5) it will take half hour to complete and restart your system.
    May 21, 2010 | Microsoft Windows XP Professional
    Wifi server
    Once you have setup the central sever you can right click either the harddrive(s) or individual folders and there should be an option to share (or sharing and security). Open that and it should be quite straightforward to setup permissions so all computers can access those network places.
    Next on the server right click My Computer and click properties. Write down what the workgroup name is.
    Now go to the Vista laptops and goto Control Panel, then network places, or view wireless devices on network. Hopefully your shares will appear on the laptops and you can access them.
    If they appear and you canot access them then you probably need to go back to step one and alter the permissions for sharing on the XP server.
    Hope this helps, www.PuterCare.com
    Apr 09, 2010 | Acer Aspire 5050 Notebook
    LDAP issues with Konica C451
    5 Network settings
    5-52 bizhub C650/C550/C451 (FE3)
    Setting up LDAP
    Register LDAP servers and specify authentication settings. Settings can be specified for the following.
    Setup LDAP screen 1/6
    Setup LDAP screen 2/6
    Setup LDAP screen 3/6
    Setup LDAP screen 4/6
    LDAP Server Name Type in the name of the LDAP server to be registered.
    Use the keyboard that appeared in the touch panel to type in the server name (32
    characters or less).
    Max. Search Results Specify the maximum number of destinations to be displayed after a search. To
    change the setting, press the [C] (clear) key, and then use the keypad to type in
    the desired setting. (Range: 5 to 1000)
    Timeout Specify the maximum wait time for a search operation. To change the setting,
    press the [C] (clear) key, and then use the keypad to type in the desired setting.
    (Range: 5 to 300 seconds)
    Initial Setting for Search Details Specify the initial search conditions for "Name", "E-Mail", "Fax Number", "Last
    Name", "First Name", "City", "Company Name" and "Department" in an advanced
    search.
    Server Address Specify the address of the LDAP server. Use the keyboard that appears in the
    touch panel to type in the address (255 characters or less).
    Search Base Specify the search starting point in a hierarchical structure arranged on the LDAP
    server. Searches are performed by also including the sub-directories lower than
    the starting point that was specified.
    Use the keyboard that appears in the touch panel to type in the address (up to 255
    characters).
    SSL Setting Select whether or not SSL (data encryption) is used when connecting to an LDAP
    server.
    When SSL is used, communication information is encrypted.
    Port Number Specify the port number for the LDAP server. To change the setting, press the [C]
    (clear) key, and then use the keypad to type in the desired port number. (Range: 1
    to 65535)
    Port Number (SSL) Specify the port number when SSL is used. To change the setting, press the [C]
    to 65535)
    Authentication Type Select the authentication method used for logging on to the LDAP server.
    Anonymous: This authentication method does not require a user name and password.
    If "Anonymous" is selected, dynamic authentication is disabled.
    Simple: This simple authentication method requires a user name and password.
    Be careful since the passwords can be leaked over the network.
    Digest-MD5: This authentication method can be used on a typical LDAP server. If
    authentication fails using Digest- MD5, the authentication is performed by automatically
    switching to CRAM-MD5.
    GSS-SPNEGO: This authentication method can be used with Active Directory in
    Windows (Kerberos authentication).
    NTLM v1 and NTLM v2: These standard user authentication methods can be used
    with Windows NT.
    They can be used for logging on when sharing files and printers.
    bizhub C650/C550/C451 (FE3) 5-53
    Aug 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
    2002 Cadillac ignition turn
    • A network is a group of computers (often called nodes or hosts) that can share information through their interconnections. A network is made up of the following components:
      Computer systems (nodes or hosts)
      Transmission media--a path for electrical signals between devices
      Network interfaces--devices that send and receive electrical signals
      Protocols--rules or standards that describe how hosts communicate and exchange data
      Despite the costs of implementation and maintenance, networks actually save organizations money by allowing them to:
      Consolidate (centralize) data storage
      Share peripheral devices like printers
      Increase internal and external communications
      Increase productivity and collaboration
      There are several ways to classify networks. The following table lists several ways to describe a network.
      Peer-to-Peer In a peer to peer network, the hosts provide and consume network services, and each host has the same operating system. Advantages of peer to peer networks include:
      Easy implementation
      Inexpensive
      Disadvantages of peer to peer networks include:
      Difficult to expand (not scalable)
      Difficult to support
      Lack centralized control
      No centralized storage
      Client/Server In a client/server network, hosts have specific roles. For example, some hosts are assigned server roles which allows them to provide network resources to other hosts. Other hosts are assigned client roles which allows them to consume network resources. Unlike peer to peer networks, hosts in a client/server network have different operating systems. Advantages of client/server networks include:
      Easily expanded (scalable)
      Easy support
      Centralized services
      Easy to backup
      Disadvantages of client/server networks include:
      Server operating systems are expensive
      Requires extensive advanced planning
      Geography and Size
      Local Area Network (LAN) LANs reside in a small geographic area, like in an office. A series of connected LANs, or a LAN connected across several buildings or offices, is called an internetwork.
      Wide Area Network (WAN) A WAN is a group of LANs that are geographically isolated but connected to form a large internetwork. When implementing a WAN, remember to provide local access to user resources to prevent a high rate of WAN traffic.
      Participation
      Private A LAN or WAN for private individual or group use which may or may not be secure. Examples include home and organization (small business, corporate, institute, government) networks. Intranets and extranets, although related to the Internet, are private networks. Both an extranet and intranet are tightly controlled, and made available only to select organizations. An extranet is made available to the public and an intranet is made available internally.
      Public A large collection of unrelated computers, with each node on the network having a unique address. The Internet, for example, is a public network. Because computers are unrelated and many companies and individuals share the same communication media, the public network is by nature insecure.
      Signalling
      Baseband Baseband signalling allows one signal at a time on the network medium (cabling).
      Broadband Broadband signalling divides the network medium into multiple channels, allowing several signals to traverse the medium at the same time.
    Jul 08, 2009 | 1995 Cadillac Seville
    C13 ...same problem!!!!
    Easy implementation
    Inexpensive
    Easy support
    Easy to backup
    Geography and Size
    Participation
    Signalling
    Jul 08, 2009 | Sony MDS-JE480 Mini Disc Player
    Installing
    1. if your internet service provider did not provide these to you, they would stay blank. (most cable broadband internet would have these blank, for instance)
    2. because you havent entered any dns entries. more importantly, most of the time what is more important is that you router is set to obtain dns from your ISP (service provider) if that is set correctly, its ok that they are all 0's
    3. whether or not your connection should be set to the automatic type can only be answered by your service provider, most cable and some DSL broadband would be set to automatic, some DSL will be set to PPPOE, which will require the username and password given to you from your ISP. If they did not give you one, most likely this would be set to automatic.
    4. DHCP server functions is what allows your individual computers in your home to share the internet if you have more than one machine. even if you do have just one machine, it should still be set to automatic.
    5. The router name is for your reference, so you should name it something that is meaningful to you.
    Mar 21, 2009 | ASUS (wl500g) Wireless Router
    I can't setup windows xp sp2 in my laptop
    why bother, go on the net and search for windows updates. dont use windows but another 3rd party site, they have all the updates to do this. i run my system on the earliest xp windows. i have to load sp1, sp2 and sp3, do you think i am going to wait 3 hours to download all the updates. 5 hours it took with the damn thing keep on switching on and off. now i load 1, 2 and 3, an hour and its all done. then just update for the extras which is malicious software update and a few security updates.
    Oct 28, 2008 | Compaq Presario Notebook
    Microsoft Windows Server Standard 2003 for PC Logo
    99 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
