Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Washing Machine shows error code C1
The service publications note that this error code is due to an issue with the motor control board, the motor, or the thermal protector. I have checked resistances at the wireharness thru to the motor and all resistances check within spec.
All solder point on the motor control board look OK and no signes of overheating anywhere.
I have also performed the automatic & manual diagnoistocs and I can get the unit to go thru a whole spin cycle, but when I run a wash cycle with clothes (even a small load of 4 small articles) The unit will trip a C1 error code when it goes in to spin mode.
Do you have any suggestions on further diagnosing what part is defective?
  • katiedyd69 Dec 01, 2008
    I have the same problem with the this Cl code. My husband has done everything the book said to do to troubleshoot. It will take 5 days for a repair guy to come out.
  • badebw Jan 02, 2009
    Same problem here. Did yours get resolved?
  • 15,935 Answers
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/15 error code on...
The error F/15 is shown on the display due to Motor Control Unit (MCU) Error detected in the washing machine.
In this problem check the MCU in the washing machine. The motor is either got stuck up or got overheated and got faulty. This will Help. Good Luck.
on Mar 11, 2010 | Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/11 error code on...
The error F/11 is shown on the display due to Serial Communication Error detected in the washing machine.
In this problem check the Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) .
This will Help.Good Luck.
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
Aug 15, 2014 | Whirlpool Washing Machines
Whirlpool cabrio with error code F1 flashing on display unit shuts down
HI. This F-1 code is in reference to the Machine/Motor Control board assembly. That entire board will need to be replaced, due to logic sector failure. The board is mounted just below the the control panel console. Use the service manual posted below this text to guide you through the replacement procedure.
Click Here to access your service manual.
Aug 12, 2010 | Whirlpool Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/07 error code on...
The error F/07 is shown on the display due to Motor Control Unit Error in the washing machine. The motor speed is not getting detected by the control board in the machine or there is a confirm short in the motor control unit.
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/06 error code on...
The error F/06 is shown on the display due toDrive Motor Tachometer Error in the washing machine. The motorspeed is not getting detected by the control board in themachine.
Error code c1 of ca
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jun 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code c1
Error code C1 indicates a problem with drive motor-thermal protector or the motor controller
may be due to overloading
Press( stop/cancel) to clear the display.
Hope this helps
Dec 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Hope this helps
Nov 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
511 people viewed this question
Dan Webster
Dan Webster
Sal De
