Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Kdf-60xs955 My television has a blue cloud in the bottom right corner, it is always their weather I'm watching Cable, Satellite or DVD. I purchased the television in 2004. Any help would be greatly appreciated. Thanks!!!
  • 3 more comments
  • Damon Royster Jan 07, 2007
    The lamp currently in my television has less that two months of usage. I don't think it is the lamp, but it is possible I bought a bad lamp.
  • Damon Royster Jan 30, 2007
    Could you get the part number for the optical block/engine? I did a search on partstore.com and the only result was a opticla guide is this the same as the block/engine?
  • Damon Royster Feb 12, 2007
    I have it in the shop now and they said it is the optical block and the repair would cost $1100
    I have it in the shop now and they confirmed that the problem is the optical block. The repair is $1100.
  • reese2 May 12, 2008
    I have the same TV. My prob. is that there is a large area of blue dots near the center of the screen. Is this a pixal prob. and how much will it cost me?
If Sony repairs the optical engine - will it just go bad again?
Posted on Sep 22, 2008
I had the same problem and the tv was no longer under warranty but sony fixed it because for free because it was a common problem with this particular model and their fault. It was not easy to get them to cooperate but with the help from my local repair service they finally did.
Posted on Jun 18, 2008
Ooh, its not the lamp, it was the light engine as per what the tech said.
Posted on Sep 08, 2007
I had the exact same problem and the blue cloud was getting bigger, thank god i purchased the extra warranty, it covered the cost, if not, the guy said it would of cost $1000 to repair.
    Scholar:
  • 119 Answers
The part # from sony for the optical engin is A1084668A sony has a list price of $1552.50 CDN. note replacing the optical engin is a difficult task in itself. the wire harnesses in the set MUST be put back in the same location when completed. if not it can cause interfearance in the picture or other problems.
Posted on Jan 30, 2007
I've heard it is the optical block...
Posted on Jan 07, 2007
Mine just started doing the same thing, I think the lamp may be going bad. Did you get your's fixed yet?
  • Gary Perkins Jan 27, 2007
    Just had a technician tell me the problem is the optical engine.
Blue dots on screen. Blue band on on/off side of screen.
blue dots on screen,bright blue haze right corner to north westpast center of screen.
May 24, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
There is a blue color invading the screen across the bottom and right lower corner and a cloud of blue developing on screen
trye to change on tube of screen hawe som resistors and 1 of transistor tere you kan meger it and you will se wich 1 need to swampe it.
Jan 23, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Large blue covering entire bottom right corner and blue dots
optical block failure call sony, they are a known fault on all rear pro sets from 2003-2007, they may replace for free, have extended warranty on this part.... there are lawsuits pending against sony over this problem
Sep 13, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue tint at the bottom of the screen
Your optical block (light engine) is going bad. A very expensive part. Sony has a history of trouble with a lot of these. Sont will also sometimes warranty them for customers. Contact them with your model, serial, and date of purchase. Good luck.
May 31, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue haze across bottom 2" of screen on sony kdf-60xs955 lcd tv
The Blue cloud is caused by a filter inside the Optics ( light engine) . The lamp over time has destroyed a coating allowing too much of the wrong spectrum of light to pass. The only repair is to replace the Optics or remove the optics and send out to be rebuilt. Call Sony and talk to customer service they may be able to help ? The bad news is this trouble will continue to get worse, the blue will continue to grow most likely.
Apr 24, 2009 | Televison & Video
Sony Projection TV - glowing blue in corner of screen
That sound like the optical Block or otherwise known as the light engine
This still may be covered by sony's warranty
I would call them and see it is a very expensive part
Feb 08, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots and blue cloud. Sony 55" LCD
Sounds like magnetic interference,Do you have a speaker close to that corner?If so you need to relocate it a little farther away.
Jan 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
807 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
