Question about Mitsubishi WT-46807 46" Rear Projection Television
Mitsub tv My mitsubishi wt-46807 does the color thing and i was wonderin what i can do to fix it. my email is artiaco07@yahoo.com. seems like when i hit the tv or stop on the floor the screen flickers as well
  • 1 more comment
  • Robert Artiaco Nov 25, 2008
    The display on the tv looks like someone put one hand on top and one hand on bottom and are squeezing the picture towards the center when it does that all the colors are a little distorted. like when i am watching ABC on tv the center of the picture is clear however the further from the center you go the more the colors are seperated. The ABC symbol in the lower right corner shows up in red green and yellow overlapping each other.. its just screwed up i thing its like a board in the tv that helps align the 3 bulbsbecause when i kick the tv it goes back to normal. either for a few minuites or all night.
    how would i identify the convergence ic? i am able to fige some stuff out i just hated to start pushing and pulling on stuff in the tv not really knowing what im tinkering with. or should i just make sure all the connections are tight? Would i have to worry about the capacitors?
    ok thanks im going to work on that now.. thanks for your help beautiful
    Sergeant:
    Champion:
  • 227 Answers
Can you be more specific ? i don't understand your posting. what is the problem with your tv?
Posted on Nov 22, 2008
  • ESTEBAN MERINO
    ESTEBAN MERINO Nov 25, 2008
    ok, you have some loose connections on the convergences IC's. you need call the repairman to do this job, he shouldn't charge you too much for this, because there are no parts to be replaced just loose connections.
  • ESTEBAN MERINO
    they are two black pieces attached to a heatsink the number starts with stk 392-........
My Mitsubishi WT-46807 rear projection TV worked fine last night but this morning though it "clicks" and the green light comes on, there is no picture or sound from the television. I have tried to unplug...
I have a 64' samsung tv , It did the same thing and it was the lamp inside it. I bought it online at parts store.com, it works fine now. We fixed it ourselves and didnt know the first thing about tvs. Good luck
Sep 29, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I would like to get a copy of the instructions to replace or resolder the convergance IC's on a Mitsubishi WT-46807 from SD Tech please thanks, DT
DT? I am becoming famous with these instructions--having done the repair hundreds of times and getting asked the same question here by many people I composed the step by step instructions.
Once you get the instructions all I would ask is you rate them with a vote on this question.
SD TECH
Jan 25, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi VS-5005R big screen
I just finished fixing one of this units and there a few thing that i changed, the voltage regulator and 2 capacitors and as prevention repair i did some resoldering in the power supply and horizontal ckt
good luck
caypianan@yahoo.com
Oct 29, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
CAYPIANAN@YAHOO.COM
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 - blue shadowing
YOU HAVE TO REPLACE THE CONVERGENCE IC'S THERE IS ONLY ONE BAD BUT IT IS RECOMMENDED THAT YOU REPLACE BOTH.
CAYPIANAN@YAHOO.COM
Aug 20, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Wt-46807
IN YOUR CASE YOU HAVE COLD SOLDER, JUST PULL THE POWER SUPPLY AND YOU'LL SEE THE CONVERGENCE IC'S THEY ARE EASE TO INDENTIFY. THE NUMER STARTS WITH STK.....
CAYPIANAN@YAHOO.COM
Jul 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
TV is Ghosting
if convergence problem color would be bowed and off. If it is the convergence replace ic stks there are 2 inside tv if you could solder and good at this stuff. parts cost is 30.00 . if you are going to get fixed cost is 300.00 . www.part store.com has parts just give them model number .They can tell you part number.I would pay someone to do this it is trickey.
I think ghosting is ground problem on cable connections check connections and replace cable wire.
thanks doctor video
May 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
WT-46807 HD PRoblems
GO TO INPUTS ON THE MITSUBISHI AND TURN THEM ON, THEY COME IN THE OFF POSITION
Nov 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
