Question about Sony PlayStation 2 (PS2) Console
How to re-connect the power ribbon of the original PS2
Was cleaning it and accidently pulled it out. It's the silver power ribbon that is attached to the lid, that i can't figure out how to reattach it, cause unsure of where it attaches to.
  • Sony Master
  • 586 Answers
   It starts from power button and other side enter in main power circuit. Just remember the other side enters in the poweer circuit where you can see the place in which it inserts.(This is for both PS2 and PS2 slim models)
Thanks for using fixya.
Posted on Nov 26, 2008
Ps2 slim/ we took it apart and there is a right angle shaped microchip inside
If this was towards the front of the console and was attached to a silver ribbon cable this is likely to be the power/eject control board.
Nov 22, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 ribbon
there are a lot of ribbon wire inside the ps2,
you can actually just insert it on the nearest slot where it is located
some ribbon wire port has a lid that snaps to hold the ribbon
Jun 23, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 broken
I have spent alot of time inside the ps2 and I know what ribbon you are talking about know did you pull it out of the slot or right off the chip canuse if its out of the slot you can easily put it back in once you find the slot but if its off the chip you may want to get a pro to solder that back on for you its very dificult and if done wrong will turn your ps2 in a useless paperweight
Apr 08, 2008 | Sony PlayStation 2 (PS2) Console
PS2 won't work, red light comes on, buttons don't respond
Sounds like the ribbon cable is ether damaged or not in the slot all the way.. that clicking sound you hear is common after extended use, all mine make the same sound ..try opening it up one more time and check the ribbon ends i know it's a pain but might be worth your time. pulling them out too hard can damage the ends.some time's putting them they seem like there in all the way but it might not be in straight.REMEMBER BENT FOLDED FLAT CABLES = problems.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
PS2 power ribbon Help!!!!!!
Use a pair of needle nose pliers and grip the connection end of the Ribbon cable by the hard plastic piece.  Insert this cable in the second connector from the front.  The connectors are located under the right edge of the CD drive.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
PS2 power ribbon
Hi Anishpp
If it came loose from the buttons, you need to remove the button holder to get to the connector. Push he ribbon into the slot on the back of the buttons.
If it came loose from the motherboard, you will have to remove the guts of the PS2 to see the connector under the cd drive right side. This is done by removing 4 screws. Two are on either side of your Controller ports. Another one is located between the fan and power block. Another is to the left of the powerblock. lift the guts from the back and pull the system out. looking at the right side, plug the reset Eject ribbon into the 2nd connector from the front. Then put it all back together carefully.
Ps2 eject ribbon
is this ps2 slim or original
Aug 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
135 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
