Question about DEI GM Immobilizer Bypass
Changed batter remote start not working
2003 gmc envoy Battery was changed but now dealer installed remote start not working the remote start used to work by pressing the car remote 3 times to turn on please help
    Problem Solver:
  • 5 Answers
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Posted on Nov 22, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
My 2003 GMC Envoy sometimes shuts off while driving
Envoy cutting off - 2004 GMC Envoy - RepairPal
repairpal.com > Questions > GMC > Envoy > 2004 GMC Envoy
Sep 23, 2009 - My 2004 envoy has been cutting off ever since I replaced the battery. ...over beyond to the right and sometimes drops down way past the final. ... My enginecuts off when running air or heat what's the problem. 2003 GMC Envoy ... has recently started cutting off while in park and still on and while driving.
engine shuts down with defrost or A/C on : GMC Envoy ...
repairpal.com > Problems > GMC > Envoy
My 2004 GMC Envoy vibrates when I turn the air conditioner or heater on . It stallswhile I'm driving it and it ... 2003 GMC Envoy168,000Visitor. This solved my ... Truck will shut off while driving when I turn on A/C or heat. Also it will do the same ...
GMC Envoy shuts off while driving but starts up Questions ...
www.fixya.com > ... > Cars & Trucks > GMC
Ask your GMC shuts off while driving but starts up related question. ... after jump starting a car my 2003 envoy stalls out. dont know if computer needs ... shuts off while driving have to jiggle key sometimes to start The ignition switch is the most ...
2004 chevy trailblazer shuts off - CarGurus
Feb 08, 2016 | GMC 2003 Envoy SLE
How to break into 2003 gmc envoy,without hurting it? Key won't work,remote won't work,battery is dead.
You can usually go to the passenger door and use your key to unlock it, then reach through and open drivers door. After that pull the hood release and change your battery. If it still won't open with a key on passenger door then you will have to call a locksmith who will bring a special tool to open.
Feb 25, 2015 | GMC Cars & Trucks
Would a dead battery stop your key from turning on in a 2003 gmc envoy
Sounds like a flat battery. Just enough to power your lights but not enough to power the starter motor. Try recharging the battery.and check battery connections are good.
Feb 22, 2015 | 2003 GMC Envoy
Car alarm goes off when I use the key to open doors or start engine on my 2006 GMC Envoy. Problem started when I installed new battery.
Not familiar with the envoy, but most all GMC trucks have a alarm reset button under the dash by the steering column to reset after battery problems. Why did you change the battery? It may also be your starter has shorted out which will set off the alarm. Good Luck
Nov 23, 2013 | 2006 GMC Envoy
None of the speedometer work in my 2003 envoy what do i do
my 2003 gmc sierra had the same problem with dash and i took to the dealer
and was told that certain model of certain years had a service bulitin and if your
like mine meet the criteria that it was changed and reprogamed for free well worth
the trip to dealer to inquire on it
good luck
May 28, 2011 | 2003 GMC Envoy
2003 gmc envoy will not start, just a clicking sound, changed the starter, that didn't help, it will start sometimes with a battery charger hooked to it. what should i try next?
Check the battery cable connections for corrosion. Clean and tighten if necessary. Get the battery checked out at a dependable auto shop. Some places will check them for free.
Dec 10, 2010 | 2003 GMC Envoy
I changed the battery on our 2003 envoy, and now it does not run smooth
You will either need to reeducate the computer or have the dealer do it for you.
If you call them they can explain the procedure.
I believe it is start the car cold, let it run till warm.
Put your foot on the brake, put it in "D" then "R" then back to park, after that it could take as long as a month for the car to finnish learning.
But I would call the local Chevy dealer to get the low down for your vehical.
Aug 25, 2010 | 2003 GMC Envoy
2004 xl envoy ip lights comin on all 4 small guauges are non operational 2 large works this morning key remote wouldnt unlock doors open one door with key no other doors would unlock and the car will not...
your batter is slowly dying! replace it before its too late. i had the same problem and i kept boosting it and using a trickle charger...just change it to a good battery
Dec 17, 2008 | 2004 GMC Envoy
Envoy A/C problem connected to Recent Battery Change...
Yes there is a connection with A/C going wacky and the battery disconnected for any reason, due to poor design. Upon re-connection of the battery, our actuators have a good chance of blowing. Pretty common problem, they should have disconnected Fuses #10 and #28 before hooking the battery back up.
Apr 12, 2017 | 2003 GMC Envoy
DEI GM Immobilizer Bypass Logo
908 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
