Question about Kitchen Ranges
Electronic Ignition for Gas Stove Doesn't Work
We just bought a house that has an older 24" Hotpoint Gas Stove. The gas *was* on and the plumber tried to get the stove to turn on. Gas comes out, but there was no "clicking" or lighting when the knobs were turned to the "light" position. He doesn't know whats wrong and just turned off the gas to be safe. Since it is a custom size and we are broke I am hoping this is an easy fix. Also, I don't think it's related but at some point in the past the pipes burst and flooded the kitchen.
We have the same problem constantly. We have discovered that if we disconnect from electrical outlet, we "reboot the interior control" and it starts again. Said to say, tonight it doesn't seem to be working. I hate these! I'm going to go look for an "old fashioned gas range."/
Posted on Apr 17, 2010
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
MABE Stove Manual in English Model : EM6120B2
hello i recently bought a mabe 6 burner gas stove but i need to know the manual is not in english and do i have to plug in before i can turn the gas on? its electronic ignition by the way
thanks
customer
May 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
May 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas burners/electronic ignition
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
INSTALLING A GAS STOVE
you would need to get a LICENSED plumber for the installation of gas line. did i mention LICENSED??? its your house dont mess with a guy that tell you he's done some plumbling before
Mar 16, 2008 | Kitchen Ranges
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Kitchen Ranges Logo
1,210 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
