HTC G1
Problem for HTC G1
How do you download photos from G1 to laptop?
By baumgartn277 on Nov 22, 2008
How do you download photos from G1 phone to a laptop?
I tried the USB port adapter between my phone and computer, except that the computer isn't reading a device to get photos from.
any advice is much appreciated.
Lisa
Comments:
Nov 22, 2008
- Yes, it reads Removable disk F:
Nov 22, 2008
- My computer reads an F: drive yet when I try to have adobe photoshop go to F: drive, my computer says, please insert a disk into drive F:
thank you for helping...!
Nov 22, 2008
- I appreciate your looking into it. I bet they won't have a clue at the tmobile store ;-) And there aren't instructions in the G1 user manual nor on Google search engine!
Thanks Vincent!
Lisa
Nov 22, 2008
- oh it would be a nugget of joy if I had that option appear "Use for USB storage." My SD card menu has 3 options: 1) total space 2) available space 3) unmount/eject SD card. Nothing happens when I click option 3. Though when I plug the USB cable the G1 says USB connected.
if you think of any other nuggets of joy for me, I much appreciate those gems.
Lisa
Nov 24, 2008
- You are a kind genius...! That worked. And I can't tell you how surprised because before that my photos were missing from the G1 phone altogether from all the futzing around with the SD menus option! My camera stopped working too. Maybe now that will also be resolved via that drop down menu with the mount feature. Bless you Bubbabear!!! Lisa
Same Problem
May 21, 2009
-   Lord2099 has it right. try it. -   Guest
May 16, 2009
-   Thanks that worked for me too!!!!! -   Guest
May 02, 2009
-   g1 how to upload pictures onto computer?-   Guest
Apr 30, 2009
-   My computer does not recognized my G1, I want to download some pictures and I cant, anybody who can help me with that -   evaliente1
Apr 28, 2009
-   same here... -   Guest
Best Solution
posted on Dec 05, 2008
Very Helpful)
seashells4me
Rank: Apprentice
Rating: 100%, 37 votes
Step 1: Plug in your USB cable to your G1 T-mobile phone as well as the computer.
Step 2: On your G1 T-mobile phone you will see a small icon at the top of the screen that symbols the USB.
Step 3: Pull down the notification window down and click on USB Connection.
Step 4: Automatically on your laptop computer or just computer a window will pop up giving you the option of importing pictures and copying them or just viewing them.
These steps are the correct steps.....T-mobile G1 technical support has not yet modify these steps or include them on the T-mobile G1 manual.
By Mariel Canjura
Bronx, NY
Was this helpful?
Yes
No
34 people thought this was helpful
Solution #2
posted on Nov 22, 2008
Very Helpful)
Bubbabear64
Rank: Wiz
Rating: 85%, 2148 votes
If vsrights solutions don't do the trick:
I heard from T-Mobile that there is an over the air upgrade that is going out to all G1 phones. This will correct some problems with transferring pictures to your phone and computer as well as syncing music.
Contact 611 from your cell phone and say G1 support for details.
In the meantime if you have a SD adaptor for your memory card as well as a card reader from your cell phone, it will work as a drive.
You can transfer pictures to your photo album on t-mobile.com as well from your phone. Once they are in the album, you can upload them to your computer as well.
I have been having similar problems syncing music with the phone plugged in.
Was this helpful?
Yes
No
Solution #3
Helpful)
vswright
Rank: Wiz
Rating: 84%, 47 votes
Hello Lisa,
When you plug the USB cable into your computer does the computer recognize a new device?
- Vincent
Comments:
Nov 22, 2008
- So far so good! Does the F: drive have folders in it you can explore or is it empty?
Nov 22, 2008
- I am not having any luck seeing a specific fix this problem. I will continue to research tomorrow and see if I can find a fix.
- Vincent
Nov 22, 2008
- I think I found a little nugget of joy...
go into settings, sd card & phone storage, then when you connect the usb cord in your computer or g1. check the "Use for USB storage" to have it connect to your computer. Then to reconnect the sd card to your G1 just uncheck the "Use for USB storage"
- Vincent
Nov 22, 2008
- Okay here is some more info:
I was having a similar issue to that of the original poster in that I had photos on the G1 which I couldn't seem to get off of it and onto my PC using the USB cable.
The instructions say to select "Use for USB Storage" in the "SD card & phone storage" settings menu, but I wasn't even getting this option in the settings menu - even with the cable connected.
Meanwhile, on the (XP) PC, I was seeing the USB disk device from Windows Explorer. It was listed as "Removeable Disk", but the disk appeared empty and when I clicked on the disk in Windows Explorer, I would get a pop-up dialog that said "Please insert a disk into drive F:" (as this is drive F on my PC).
Call me dense, but it wasn't until a day later that I finally noticed that there was a notification in the top status menu when I connected the USB cable. If you drag down to look at the notifications menu, you should see an entry which says "USB Connected - Select to copy files to/from computer". All you need to do is touch this menu item and you will be prompted to Mount the USB. Choose "Mount". Once mounted, your USB will be connected and you will be able to see it from your PC - you can copy files to and from the card willy nilly.
I have yet to find anything in the manual that came with the phone that talks about the Mount option being in the Notifications menu. This is very confusing, especially since there are two (read two) different chapters entitled "Memory Card" - one in the "getting started" section, and one in the "having fun" section, and neither of these chapters mention anything about the disk "Mount" command, or the fact that you will need to hunt for this option in the Notifications menu. Instead, the manual sends you on a wild goose chase with incorrect instructions about finding the "Use for USB Storage" in the "SD card & phone storage" settings menu, as mentioned above.
Oh well, now that I'm done venting, I am a happy G1 user once again as I now have my pictures which I took last Thursday night at the "Tavern" restaurant/bar in Buckhead, Georgia - MAN what a bar! Never have I seen such a concentration of lively, beautiful women in one place!
Here is the webpage: http://forums.tmonews.com/index.php?action=printpage;topic=4009.0 - Vincent
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Feb 08, 2009
Helpful)
Lord2099
Rank: Apprentice
Rating: 91%, 8 votes
when you connect your g1 to the computer, you will get the little sound and the computer will detect the device but doesn't pop up the autorun. the easy solution is that you will see the little usb symbol on the phone in the upper left hand corner in the notification area. slide the notification area down and you will be given the choice to copy files to/from the phone to your computer. when you select that, you are given an option to mount the drive onto your computer. accept that, and then the computer will do the autorun thing giving you access to the memory card from the computer without having to pull it out of the phone.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for HTC G1
Questions and Unsolved Problems for HTC G1
Do you recommend HTC G1?
Answer
Answer
my screen on my G1 broke, can it be fix?
Answer
i just got a g1 and when i try to sign into msn it says the phone number cannot be read from ypur... (More)
Answer
i got a g1 and it says to enter g_mail account but i dont have internet
Answer
i don't have no sound when i get a text message but why i can hear it when i get phone calls please... (More)
Answer
it keep on turning off randomly..i tried to take out the battery and all.. What should i do??
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 30, 2009
i cant take the photo that i threw to post it to my laptop ..why is that
Comment by gjoe, posted on Mar 13, 2009
Cant get the computer to recognize my phone
Comment by shundongyao, posted on Feb 17, 2009
I have the same problem
yes, I have big problem with my G1, because I had almost 200 pictures in my phone, and those pictures were taken during my travel arround three countries. anybody can help me with the instruction, will be so greatful
Jack yao
Comment by sexyme1, posted on Jan 03, 2009
im having the same problem i cant get my picture from my phone to my labtop
Comment by GT3000, posted on Dec 16, 2008
Ok i load photos on my phone from my computer but my phone does not recognize them. I downloaded a photo online directly to my phone and my phone reads that picture. Both photos, the one that my phone cant read and the picture my phone can read, are both j peg formats with similar file sizes. Am i looking in the wrong place or is this a glitch that has not been fixed. Or is there a better file format to put the pictures under.
Describe your PDAs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in Newport, KY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
