1 document stuck in que
Will not print or delete? now i even tried to uninstall the printer and it wont delete? help!
  • Anonymous Dec 07, 2008
    i have tried turning off printer, unplugging printer, rebooting
    computer lots of times, and still documents go to queue instead
    of printing.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Hello u6rysl,
Turn the printer off.
Reboot your machine.
Go back into the print queue and remove the print job.
- Vincent
Posted on Nov 22, 2008
How can I clear the print que? I tried to cancel printing a document, and now the que says cancelling, but won't let anything else print
1) Try to restart you system with the printer unplugged.
2) Try to Pause the printer and then delete the items in the que
3) If this doesn't help Delete the printer and re-install it.
Aug 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
Dell V715w all-in-one print job stuck in que
If you have Windows OS, try this:
Clear Printer Spooler files and enable the Spooler service.
a. Click Start, type "services.msc" (without quotes) and press Enter.
b. Double-click "Printer Spooler" in the Services list.
c. Click Stop and click OK.
d. Click Start, type "%WINDIR%\system32\spool\printers" (without quotes) in the search box and press Enter. In the open window, and delete all files in this folder.
e. Now, go to “Services” again. Double-click "Printer Spooler".
f. On the General tab, next to Startup type, make sure that Automatic is selected.
g. If the service is not already running, under Service status, click Start, and then click OK.
Jan 27, 2018 | Dell All-in-One Multifunctional (v715w)...
Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.
Good Luck
Aug 16, 2012 | Dell All-in-One Multifunctional (v715w)...
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
Mar 25, 2010 | Dell 966 All-In-One InkJet Printer
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
Dell 948 printer will not delete a document
try putting a sheet of paper on the printer and hit the print button..
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Printer won't connect to computer
In Order to delete the Doc stuck in Que............ Go to start click on Run if it is a Vista just type it in Start Search.......... Type Services.Msc and hit enter.......... On that list select Print Spooler right click on it and say stop................ Now click on Start again and type in Spool and hit enter............. Double click on the Printers folder there and select each and everything there land hit delete........ Now that should become empty close that window........... Right click on the Print Spooler and click on Start........... Now go to all Programmes go to Lexmark X***** Series Printer u have and click on Uninstall......... Restart the Computer.......... Download the drivers from the website and install the downloaded drivers it will work................ Thanks
Jan 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
367 people viewed this question
jasbo
jasbo
