Question about Acer Aspire T310 PC Desktop
Just doesn't work
When i go to turn on my machine it sometimes makes it as far as loading the xp screen but other times just refuses to aknowledge its even on, i have no idea what is causing this it will also sometimes attempt to start in safe mode then merely say 'no signal' and not respond to anything i have once seen an error message although it wasn't on screen for long enough before the screen went black and said no signal then the fan seems to run at a very high rate for no reason as it is not hot at all, i have changed screens and vga leads with no success, i have also put my hard drive into an identical pc which worked thus ruling that out as a basis for a fault, however i am no closer to resolving the problem, please help, thanks
  • rich rich Dec 24, 2006
    thanks for your suggestion, i tried however my pc wont stay on or un-frozen for long enough and doesn't run the disc drive at all so i cant attempt a repair, also i di use my hard drive as a slave if that makes any difference in being able to help, and it ran fine with my friends hard drive as the master.
TRAP00000006 ========================================EXCEPTION==============================================
tr=0028 cr0=00000011 cr2=00000000 cr3=00000000
gdt limit=03FF base=00017000 idt limit=07FF base=00017400
cs:eip=0008:68004716 ss:esp=0010:00062698 errcode=0000
flags=00010013 Cy NoZr IntDis Down TrapDis
eax=4F5FB31A ebx=F4004013 ecx=8A000044 edx=1E534D0D ds=0010 es=0010
edi=68004716 esi=F000051D ebp=2000061F cr0=00000011 fs=0030 gs=0000
Posted on May 01, 2008
I have the same computer as you and the same thing happened to me. On my computer it turned out that my motherboard crashed. you may need to buy a new one. If not then it might just be really dusty. If you have given it a good clean you should take it into a computer store to get it fixed. I know its abit late but meh.
Posted on Jun 16, 2007
    President:
  • 2,961 Answers
You say you put the hard drive in another pc and it worked. Did you put it in a slave, because windows XP will not boot on a different pc because of hardware changes and the need for different mobo drivers etc. If it did boot you were lucky as it checks processor serial numbers amongst other things. If it was a slave, it may work, but as a Windows C drive it won't work because it has probably lost the boot ini file or has a damaged HDD sector. or corrupted. You will have to boot up with your windows cd and press enter then 'R' for repair when asked to install or repair.
Posted on Dec 24, 2006
  • andrew pester
    andrew pester Jan 01, 2007
    It maybe then that your processor is faulty and failing as soon as it gets hot as it wouldn't take long to warm up, as after the cmos chip has checked settings, it's then upto the CPU to run the motherboard.
PC won't stay on, doesn't make it past the boot up menu
the fan on the CPU working? Try a different power supply the one you have might be faulty
Nov 18, 2012 | HP Computers & Internet
My old ps2 controller is not working. i used a new controller but it still doesn't work. the new controller was tested on another unit and it works fine. so i guess its the console itself is the...
See if your ps2 controller hub or port is damaged. If any pin is twisted try to get it straight and if you can't fix it, take the console to a service center.
Oct 13, 2011 | Sony PlayStation 2 (PS2) Console
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi, My Sony Vaio DVD Windows Vista computer will play some DVDs without difficulty, others it refuses to play at all, and on others, it will play all of the movie except for five minutes in the middle....
Just due to dust on your dvd lens run dvd lens cleaner and after load full drivers of dvd which either given you on time of buying or you have to download from sony site
Feb 02, 2010 | Intervideo WinDVD 5 for PC
Left turn signal doesn't work some times.
signal switch replacement is a common issue, i've replaced 5 so far.
Sep 22, 2009 | 1996 Chevrolet Blazer
Please Help Me!
Yes your asking too much of it,
An old system cannot keep up with all the memory intensive programmes and the processor will not cycle the information fast enough for you
This is why it is slow
add more ram, bigger hard disk drive too will help
if you can
delete anything off it you can too
increase the page file size,
will help
Regards
Richard
Apr 25, 2009 | Gateway Essential 466 PC Desktop
Cold water runs into the machine very very slowly.
sometimes the valves on the house could be at fault disconnect the hoses agian put end of hose into bucket turn on vavle one at a time to insure that the house supply valves are not at fault. before hooking up hoses check screens on inlet valve to washer to make sure their not blocked
Dec 16, 2008 | GE WBSR3140DW Top Load Washer
Desktop will not load up
The computer should be fine, make sure there is no dust covering the fan or inside the computer. If not you can use the recovery disc that came with the computer, or a Windows XP cd to fix your installation, if that is the problem.
Aug 13, 2008 | HP Pavilion a1010n (PS563AA) PC Desktop
XP refuses to restart after installing printer
It’s not uncommon for software to mess up during installation.
Or even have a bad CD. (Please make sure you're windows XP software is up to date, run windows update service).
Since you are able to get into windows, open control panel, open add/remove programs & uninstall the Lexmark printer software. After uninstall restart the PC. Power on the printer before windows loads. See if windows runs with the printer connected & powered on. Less Its driver software. Windows should see the printer & ask for the software. (If so, it may be corrupted software). Go to Lexmark for driver software & download it.
http://search.lexmark.com/printer/US/en/1410000
Try reinstalling using the online driver software for the X3550 printer. If it still stops you're windows, I would suggest replacing the USB cable. If replacing the cable does not help & windows does not load, there could be something wrong with the printer.
If this is a new printer you should contact Lexmark.
http://support.lexmark.com/static/229-1-0-582.html
Lexmark will suggest all of the above. You'll be three steps ahead of support. Lastly, I have come across an issue from time to time installing printers software into Windows XP systems.
(It matters not the printer model). Windows was missing basic printer files needed to operate any given printer. The fix for those systems was a complete fresh install of windows. Its suggested to never use a copied windows CD. It matters.
Good Luck electrics!
If I can help you further, feel free to post.
There is rarely 1 way to fix every thing.
Mike
May 30, 2008 | Lexmark X3550 All-In-One Printer
Motherboard upgrade
The different hardware components on the new motherboard require different drivers that what are already loaded on your installation of Windows. My guess is something requires a driver that the base Windows driver install will not cover and as a result errors out and restarts. I too have tried this trick on several occasions, sometimes it work and sometimes it doesn?t; however, the key is similar hardware. My guess would be IDE controller, video, chipset or perhaps USB 2.0 is causing your problem. What you can do perhaps is boot into Windows safe mode and try to figure out what is causing the problem. In the long run it may save time and aggravation by just reinstalling Windows ?? Let us know how it turns out.
Jan 02, 2007 | MSI RX480 Neo2-F Motherboard
Acer Aspire T310 PC Desktop Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
