Question about Dryers
KENMORE DRYER HEATING PROBLEM
MY KENMORE DRYER WORKS GREAT ON THE FIRST LOAD, THEN IT QUITS AND I HAVE TO WAIT FOUR OR FIVE HOURS BEFORE IT WILL START UP AGAIN, AFTER IT COOLS DOWN. WHY ??
    Problem Solver:
  • 10 Answers
You need a new Motor. The thermal overload on the motor shuts it down,until motor cools down.
Posted on Nov 22, 2008
I have a kenmore series 90 110 electric dryer that sometimes starts and sometimes does not. If it has not been running it starts right away, however, when I switch loads and go to push start, it sounds...
Hi ... yeah you have a bad motor... It over heats and thats why you can't start it right after it was in use.... its needs time to cool down before it will start
Mar 23, 2011 | Kenmore Dryers
No heating
Greetings,
The heating elements do not cost $200 USD buy $80 for both; available online from the most common Fisher-Paykel parts supplier.
Good luck
Apr 13, 2010 | Fisher and Paykel SMARTLOAD DE62TG1...
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
My kennmore dryer wont start. sometimes when i disconnet the power it seen to work but after a while it wont work and also smells like burn model #66932691
Hi, It sounds like maybe a motor over heating. If you can use it one load and try to restart it, and nothing happens, wait one hour and try again. If it starts, it is probably the motor. Does any of this sound like your simptoms?
May 08, 2009 | Kenmore 659 Electric Dryer
Kenmore Elite Dryer stopped working
most of the time if you push the start and it drags the motor is getting to weak to turn the drum(bad motor)if it's not heating also,it might be the heating element or the heater box fuse.if it was me i would sell it on craigslist for parts,and buy another one on craigslist(great deals)
Apr 20, 2009 | Kenmore Dryers
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
We must wait one hour to dry 2nd load
you have a bad motor the internal overload is cutting it off when the motor gets hot and that is why it takes about a hour for it to cool down before it will come back on the fix is replace the motor which is very expensive or buy a new dryer
Dec 28, 2008 | Whirlpool LGV4634JQ Gas Dryer
Heating Problem
If this is a gas dryer, you probably have bad valve coils, they can work intermittently, usually for the first part of a cycle, but when they heat up the internal resistance gets too high and they fail to open the gas valve. Once they cool off, (by continuing to air dry) they will work again for a few minutes. They will also make a buzzing/rattling (maybe "metal" ) noise as voltage is applied. For any Kenmore gas dryer, get part #279834 it contains both valve coils. Very easy to replace. Another possibility is that your duct work is plugged, check airflow. Hope this helps.
Sep 14, 2008 | Kenmore Dryers
Kenmore Dryer works for about 20 MINUTES, not seconds
SD, doesn't sound like the same problem. Yours sounds more the like motor kicking out on overload and when it cools down you are able to start it again. The thermal fuse and high limit TCO are non resettable so you can rule them out. You are going to have to check some things out. Make sure the rollers and pulley are not binding. The blower wheel is not binding. These things will cause a drag on the drum and put a heavy load on the motor. Catriver...post back
Feb 12, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
