Question about HP Office Equipment & Supplies
I have an HP PSC 1300 Series, eulatory Model SDG6B-0303. When printing a document today, it said that the black ink cartridge was low, so I changed it. Then, when I tried to resume printing, it said the color cartridge was low, so I changed that, too. (I did do the "scan" process after each cartridge change, as required.) When I tried to resume printing, it would go so far and then stop again. When I press "resume," it starts again but stops again before finishing the 2nd page of a 3-page document.
  • 962 Answers
Try removing the printer then reinstalling it. If you have a disc. I think they have discontinued driver downloads for HP PCS 1300 and 1400. Do not remove it if you do not have an installation disc.
Posted on Nov 22, 2008
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
How to install the print cartridge on the hp psc 2175
I found this site where you can see exactly how to access and change your printer cartriges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu05206&lc=en&dlc=en&cc=us&rule=22474&product=90809
Hope this helps. Bud
Jan 21, 2009 | HP PSC 2175 All-In-One InkJet Printer
Hi hello
You must replace both ink cartridges with GENUINE HP ink carts..
Jan 20, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Won't print docs in black ink
The application that you use to print may have been cofigured to avoid the black color.
And sometimes a virus has affetced your application e.g. MS Word.... this may cause the printer to print in any colour.
In this case you should reinstall the application. (first completely remove the application).
Mar 18, 2007 | HP PSC 2355 All-In-One InkJet Printer
89 people viewed this question
Ben Johnson
