Question about O2 Xda II Smartphone
Urgent I have problem with starting my O2, when I put battery inside all I get is main screen with O2 sign in the midlle without light and can`t start the system even when I press the power button.When I take out the battery screen becomes blank.When I try to connect O2 to PC,PC doesn`t see O2. What can I do to solve this problem. Thanx!
    Problem Solver:
  • 7 Answers
Attempt a soft reset and let me know..
Posted on Apr 26, 2007
Won't start up
Either power or logic board problem. If it chimes but does not boot and the screen lights up then it is a good sign. Will it do anything?
If does nothing try a different power supply first.
Try removing battery and disconnecting power supply, then try to start it without battery and just power supply.
then try charging the battery overnight. If the lights on the battery show any charge after a few hours with it plugged in and the computer turned off, try letting it charge overnight and then try starting it without power supply connected. If none of these thigs help, I would have to look at it.
Apr 05, 2014 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apartments main fuse blows
There is no reason why any coffee maker by itself draws so much current that it causes a main fuse or breaker to open. If you are shutting down all electrical use such as other appliances and lights and the fuse is still blowing, you need to have an electrician analyze the flat wiring and the over current protection devices (fuses, breakers) for malfunctioning or perhaps inadequate capacity.
Jan 02, 2018 | Isomac Zaffiro
I have a toshiba satellite a45 s150 and i replaced the hinges and put it back together and now the power wont come on and i see an error light flashing
just try with removing the battery and also see the when you fixing the hinges there are no wire stuck inside in hinges. direclty connect the main power and start without battery.
Jan 30, 2010 | Computers & Internet
My Compaq 7400 laptop was working fine but put aside to use another computer. Started it up - no front LED indicator lights - sudden shutdowns - battery apparently not charging. New battery - charging -...
If the notebook has been almecenated with battery's in place, check battery holders for sulphite (Light blue dust-like substance) in the connection points.
Using a sand paper, remove this substance. DO NOT ALLOW IT TO GET INTO YOUR MOUTH. That should work, but if the sulfite extended to the inside of the unit, then you may have to dismantle, clean and reassembly the notebook.
Nov 20, 2009 | Compaq Armada 7400 Notebook
Peugeot 406 hdi executive 2002 will not start
immobiliser problem main dealer me thinks
Aug 18, 2009 | Peugeot 406 Cars & Trucks
I JUST purchased a laptop (toshiba sattelite L300D) I put the battery in, I pluged the AC...and I start it up for its first time....but nothing appears on the screen.....not even a bios or whatever...the...
I would not even touch it, if you JUST purchased it take it right back.......if your having problems with it straight out of the box its prob. not a good sign........
If you dont want to take it back , take out the battery and put it back in...plug it in and start it up again....take notice if there are any power lights on the laptop that turn on , or if there is no response from the laptop at all.....
If there are no lights it may be a problem with the ac adaptor or the power supply inside the computer.....
If there are lights and nothing on the screen then the LCD is faulty.
Oct 04, 2008 | Toshiba Computers & Internet
Lights go out on dash DIC
make sure you clean your positive battery terminal. It can be quite corroded in there without any outside signs. Next check ground connections (main ground is under the underhood fuse box...is it rusted down there? If it's none of those, start looking at the ignition switch.
Sep 29, 2008 | 2000 Pontiac Grand Prix
Boot Problem
try to insert the battery charger into the laptop without the battery.
Dec 24, 2007 | IBM ThinkPad T30 2366 Notebook
Battery problem
preform a soft and if necessary a hard reset back info to pc first http://www.pdacortex.com/pocket_pc_sites.htm Pocket PC Sites
May 10, 2007 | O2 Xda Atom
O2 Xda II Smartphone Logo
49 people viewed this question
Top O2 Computers & Internet Experts
zurysk8
Level 1 Expert
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
