My internet cuts out all the time when I have d-link wired router,even after a reboot to the unit, works for a short time then disconnects
  • bcgrhewitt Nov 22, 2008
    Thanks,I will give a shot cheers Brett
  • 981 Answers
Does it depend on the socket you use or the router configuration at all? Your NIC or the D-Link can have bad ports; you might have wacky drivers or firewall software around; the D-Link might have scrambled config files you should reset rather than rebooting. Happy hunting.
Posted on Nov 22, 2008
Wrt330n
you should use wifi no cable so it is going to work
Oct 23, 2017 | Linksys Computers & Internet
Was having problems w/ internet connection. Brighthouse tech just left. Replaced modem and fixed a loose wire at box outside. Still won't hook to wireless and says that it is probably my router
If you have a separate modem and router turn both off and reboot only modem till all lights up the reboot router till all lights up in that order sounds simple communication problem between router and modem. If router modem combo unit disconnect either dsl or cable from router/modem leave diconnected for a short time then reconnect and reboot till all lights up. Hope this helps.
Sep 01, 2012 | EnGenius ESR-1221 EXT Router
I keep losing my internet connection when I use the wireless router. When I disconnect the wireless router, internet works great but when I reconnect it it keeps cutting out. I unplug it for ten seconds...
Try changing the channel to 11. Cordless landline phones often interfere with the default router channel. It can even be your neighbors phone that is conflicting.
Feb 06, 2011 | D-Link DIR-615 Wireless Router
The internet will cut out after short periods of time
Try changing the Ac adapter for the router and after changing it do a reset.
It should work perfectly
Jun 07, 2010 | D-Link DIR-300 Wireless Router
Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Nov 24, 2009 | D-Link DIR-615 Wireless Router
The D-Link Modem will not stay connected for online work 75 per cent of the time. I must disconnect power for 30 secs. then I can get online.
Is your unit old or new? Basically, there could be other factors giving you that intermittent disconnection from the internet. One is your ISP's internet connection that could be intermittently cut, or your browser refresh rate. Check out this two before you can conclude that the router is the problem. First change your browser to Mozilla Firefox. We had experienced the same problem with Google Chrome and IE not too long ago. If all browsers behave the same, then try to ask your ISP regarding your DSL issue.
Nov 06, 2009 | D-Link DSL 300 Modem
Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Oct 01, 2009 | Sony CDX-M610 CD Player
GETTING INTERNET LINE BUT IT IS NOT STABLE
Is it hard wires ie: dsl or high speed internet thru your cable TV lines, even if it wi fi you have a maodem hooked up to the phone or cable lines or satellite.Try rebooting the system including your modem & all routers. this is best done w/ computers off . Turn them all off or unplug them for at least 30 seconds. Then plug them in - one at a time , modem, routers, computers. If this doesn't work. Disconnect them from each other. There is a reset button on your modem & routers - push this is and hold for a minute, do each component separtely. Repeat reboot process.
Mar 21, 2009 | Lands Phones
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Computers & Internet Logo
David Payne
David Payne
