Unable to get connected via wireless on AZTECH ADSL2+ WIRELESS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:''Table Normal''; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:''''; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:''Times New Roman'';}Dear Support,
I would appreciate it if you could help me with a problem I have in getting online via the wireless feature of my broadband modem. Connectingusing Ethernet cable is not a problem, however.
My wife and I have a company laptops and we often work from home. Becauseof this problem we have to use cable connection every time to get online. We have connected via wireless on other less known wireless modem brands at relatives’houses, office lobby, airports and this leads me to believe that the wirelesssoftware on my company laptop is not the problem. I suspect it is to do withsome configuration that I might have missed (though I followed theinstructions in setting up wireless connectivity andtried to comb through the settings, but to no avail).
The strange thing is that since I bought this modem about a year ago I have managedto get connected about 3 times. However, reconnecting after a successful connectionis terminated has never worked. Most of the time it just refuses to connect.
I’ve tried to keep the wireless “open” without password toconnect, thinking that this would remove some arcane restriction, but it doesn’thelp. I gave up trying for a few months now sulkily resigned to cableconnection until my spouse recently pestered me to somehow resolve it or getanother modem.
Anyway, here is the typical sequence and when it fails.
  1. Preparing to connect
  2. Associating
  3. Preparing authentication info
  4. Authenticating (it is at this stage that it usually fails, though I remember it failing at step 2 sometimes).
Step 4 takes a while whichis normal before the it spits back a disappointing message
''Authentication failed - Unable to reach server to complete authenticationrequest.''
If you can please help me with this problem, I would be mostindebted and grateful as it would definitely increase my happiness, get my wifeoff my back and save a few bucks while at it.
If you need more info to troubleshoot, I would be glad tohunt it down in settings and provide.
Thanks & regards,
Daniel Yii
  • Gus Gaglio
    Gus Gaglio May 11, 2010
    It appears that the "Encryption" requirements between your Workplace and Home network are the issue.
    You did not state what type of wireless card you are using and what is the speed? 811a /b /g or /n? . These questions must be answered before any meaningful info can be supplied to you
    "Don't Fuss Ask Gus"
5 Suggested Answers
  • 86 Answers
SOURCE: wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
Posted on Jan 21, 2008
  • 173 Answers
SOURCE: wireless not working
Check for the wireless security settings in your modem.. and check if your airport is connected properly, if it is connected properly, then you would get a valid ipaddress, try resetting the modem and reconfigure your wired and wireless settings, if possible , try to upgrade the latest firmware for your modem and then reconfig it..
SOURCE: Securing wireless
start-run-cmd-ipconfig- get the router default gateway- enter those no's in the internet explorer select the wireless settings and security type wep or wpa . for few routers u can generate the wireless key automatically for others wireless key needed to entered manually for wep key length bw: 0-9 and A-F if 64 bit 10 digits and 128  its 26 digits
Posted on Nov 04, 2008
yboyandrei
  • 828 Answers
SOURCE: bought a new laptop; want to connect it to this modem via wireless
is your pcx1100u cable modem is not wireless ready? only router have a wireless lan... buy it...
Posted on Jun 17, 2009
  • 630 Answers
SOURCE: settings saved do not match requirements on this computer
Go into network connections on the laptop and select the Wireless Network. Go into properties and find the TCP/IP settings and ensure that the IP address setting is set to Automatic and the DNS settings also. If you have wireless security set on the router you will have to set that up on the laptop as well.
Posted on Jun 30, 2009
Want w8 foe Adsl2 Gateway Wag300n-uk driver
Repost in proper section
This is automotive questions
Aug 31, 2013 | Linksys Wireless-n Adsl2 Gateway...
How do I connect iPad to linksys x2000
Connect it using WiFi or just go to your setting and the try finding your WiFi name to connect it.
Aug 28, 2012 | Linksys X2000 Wireless-N ADSL2 Modem...
The Internet LED is red when there is no Internet connection
Unplug router for a minute or so and re connect also check if the computer is even recognizing the router in control panel under network conections
Jul 09, 2012 | NETGEAR CONSUMER Netgear Dgn2200m Wireless...
I just installed a Motorola SBG6580. I have it connected via Ethernet to my desktop (MS XP) and via wireless to one of my laptops (MS Vista). Both work well. However, I have been unable to connect my...
Try changing the authentication type to WEP/WPA/WPA etc. Might be your XP laptop doesn't support current authentication type. Thanks for joining us. Have a nice day.
Feb 24, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Modem:AZTECH DSL605EW Hi i have no lights on my ethernet (1,2,3, &4) lights. What does this indicate?
It will be lit up if there's a Ethernet Cable Connected to either of the 4 ports. If you will be using a Hardwired connection to connect the Computer to the router you will see that the light on the port where the ethernet cable is connected will lit up. However if you will be using wireless connection then it wont lit up.
Thanks for using Fixya.
Jul 29, 2010 | Aztech Computers & Internet
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
HelpMe plz
As far as I know, wired or wireless modem don't have any time limite set. unless it is set by the user.
check with your IPS (Internet Provider).
are you using dialup or cable???
Nov 10, 2008 | Computers & Internet
Securing wireless
Nov 02, 2008 | Computers & Internet
Computers & Internet Logo
132 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
