Question about IBM MOUSE APTIVA 2-BUTTON BLK WIRELESS 76H0890
Ibm wireless mice model ro07uo
Hi i bought a wireless mice from a friend and i can`t change the orientation of the button. what i mean is that i want to change the left clic to the right
best regards
sylvain ouellet
rimouski quebec
    President:
  • 8,637 Answers
Go to control panel and click on the Mouse icon. then when you get the Mouse Properties window, go to Buttons and go to the Left Button and using the drop down change the key to function as you desire. You will also have to reset the right button to use to double click to open programs. Hope this helps. Bud
Posted on Jan 17, 2009
I touched a button on the keyboard that turned the page sideways.. it turned it to the left. how do I turn the page right side up?
Actually you hit a combination of keys. Most likely you hit Ctrl+Alt and an arrow key. Try Ctrl+Alt+the up arrow. If that rotates the screen to upside down, repeat the combination twice more (or use Ctrl+Alt+the down arrow twice).
If that doesn't work, if you have a Windows OS, try the Screen Resolution or Graphics Display settings. Right click on the desktop anyplace with no running programs or icons, select Screen Resolution and then change the drop down for Orientation. This works on my desktops. For my laptop, it's the Graphic Display and then a similar orientation label.
I hope this helps.
Sep 10, 2013 | Logitech Y-RAZ71 Wireless Multimedia...
I have Model 1058 Mouse bought 12/09. Computer crashed (motherboard) and had to get new one. Can't find installation disk for mouse. Can you help?
change the mouse battery and there is a button named connect on mouse keep pressing the connect button for 3-4 minuts and keep mouse near wireless device which is connected to the computer in USB port then restart your computer and mouse will work fine.
Mar 30, 2010 | Microsoft Wireless Laser Desktop 4000...
My lenovo wireless mouse will click but not move
That only means that the lens of your pointing device is no longer responding. Sad to say but it needs replacement.
Mar 11, 2010 | IBM Lenovo Mouse 76H6618
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
My wireless mouse takes battries with short
hi,
I've got a Microsoft wireless Intellimouse and the batteries in that last for months - and it's on all the time. My wife bought a no-name mini wireless mouse and found the batteries last a couple of weeks.
The difference? My mouse takes two AA batteries, hers takes one AAA. So if you change mice(?) look for one that takes two AA batteries and stay away from any that don't.
Sep 24, 2009 | HP Wireless Optical Mouse
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
My mouse stoped working what can cause this to happen
Try changing the batteries if it is a wireless and make sure you insert them in the correct orientation. Next press the connect button on the reciever and then the connect button on the mouse.
You may find the following article useful as well:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2149
Jun 26, 2009 | Logitech Wireless Access Duo Optical...
My Logitech LX5 wireless optical mouse has never worked properly
hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
May 01, 2008 | Microsoft Multimedia Optical...
WIRELESS SWITCH
Some IBM's don't have a wireless switch. If it's asking you to check to be sure that the wireless switch is on, or it won't let you enable the radio, try a different driver. Get the make and model of the wireless card and go to driverguide.com.
Mar 11, 2008 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
546 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
