Question about Kenwood KAC-9152D Car Audio Amplifier
Fan stays on, light turns off
I connected all the wiring and when i turn the car on, the red light stays on for a second and then fades off but the fan continues to stay on. There is no audio output to the sub other than a quick popping noise when the light turns on. i checked the voltage and everything checks out fine. i am transferring the system to my new car and it worked fine in my old car. I have tried connecting the power control wire straight to the battery to see if my unit wasn't giving off enough power to keep the amp on, i got the same result.
  • gjg26 Aug 07, 2008
    i had teh same problem with the light going off and the fan staying on . i hooked up another amp a little smaller then the other one , and it worked fine, then i hooked up the bigger amp and still the same result, fan staying on and and the light goes out.
    Problem Solver:
  • 11 Answers
Try using a better ground. while new cars are great, they also have more paint and plastic in the works...so finding a good ground for your amp to run off of isnt always easy. you can try running a gbround cable straight to the negative terminal of your battery to test the amp, poor grounding is the most comon cause of amp failure. ps,the fan may be staying on as a protective service, as if your amp loses ground whenpowered up it will keep the cicuit boardfrom heating up on voltage surges.
Posted on Sep 06, 2007
My Hunter Douglas ceiling fan/light operates with a wall remote. It suddenly stopped working. When I tried out putting in a new battery the fan still does not work but the light turns on bright briefly,...
rats have gotten into your electrical wirings, probably gnawed the wires to fan totally and partially on the lights, might still find the dead rat on the wirings.
Mar 14, 2014 | Televison & Video
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Light only turns on with the remote. How do I set it to turn on with the wall switch?
There are some fan models (particularly with a remote control) that use multiple cycles of a single power switch to select the operating mode. For example, if you simply flip the switch on, you get the fan. If you flip it on, then off, then on again within one second, you get the light. If you flip the switch on - off - on - off - on, you get both. The trick is to do it fast enough so the internal power circuit doesn't run out of capacitor charge and forget what you're trying to get it to do.
Sep 28, 2011 | Hunter 52" Ceiling Fan With Light And...
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
I have a three wire switch blue+black+red for the light on my ceiling fan need to know how to hook it up to turn the light on and off have four lights used to be five but took one out cause the fixture was...
Make sure the power is off.
Connect ALL White wires together -- from the ceiling box, the fan and the lights.
Connect the Black wire from the switch to the Black wire in the ceiling box.
Connect the Red wire to the Black wire on the Fan. That should activate on the first pull
Connect the Blue wire to the 4 black wires coming from the lights. That should activate on the second pull.
The third pull should activate both. To change the order, swap the connections to the Red and Blue wires.
Jan 19, 2018 | Westinghouse Electric Ceiling Fan 3-way...
I purchased the Legrand RT1 Time Switch to run a bathroom fan. It is installed and I see indicator lights. Every time I turn the fan on, it runs for a second and stops (hearing clicking in the switch);...
You connected red and white wires together.
No problem, nothing burned out, and it's simple to fix. Steps below.
RT1 is electronic countdown timer, and electronic timer clock inside needs separate circuit, just like your alarm clock needs to be plugged in. >> that's why timer has white wire. White wire completes circuit to timer clock.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Heres what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push countdown button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 27, 2010 | Pass & Seymour / Legrand RT1-W 10-20-30-60...
Need wiring schematic telling me what wires in the harness go where.
red-power wire to power when ignition is on.yellow-battery back-up to powersource that stays live when car shut off.black-ground wire.blue-remote turn on for amplifier.blue/white-power antenna.orange or orange/white-dimmer to make deck lights fade when headlights get turned on.white and grey are your front speakers and green and purple are the rear,not sure about speaker sides though
Jan 10, 2010 | JVC AM FM CD DET FACE CAR STEREO
Unit only stays on for 4 seconds then turns itself off.
This is a short or unstable ohm load. Remove all speaker wire connections to see if the amp will stay on.
If the problem goes away when disconnecting the speaker wires try this:
1) Check volume level on zone one and zone 2 if connected. If it is too high the amp will go into protect mode and shut off exactly as you described.
2) Make sure no wires are touching any other wire or the metal surface of the amp. This will cause a short and send the amp into protect mode.
Nov 21, 2009 | Denon AVR-1705 Receiver
KP-57WS500 TV FADES TO SOLID RED W/ LINES A FEW SECONDS AFTER I TURN IT ON
Red CRT is doing short circuit in the neck. You can try to open the front panel and to hit easy the neck with wood or something and to decrease the red screen a bit. If doesn't work then replace the CRT.
Jan 04, 2008 | Sony KP-57WS500 57" Rear Projection...
Ring of light acting wierd (not red though)
Don't use the intercooler, it's really not good for the console. I'm not sure what could be causing the 'fading' effect, I don't think I've ever heard of this. Call Microsoft and explain your situation, there may also be more info on your problem on sites like xbox-scene.com or llamma. Sorry I can't be of more help but please rate if at all useful, thanks!
Dec 08, 2007 | Microsoft Xbox 360 Console
Kenwood KAC-9152D Car Audio Amplifier Logo
212 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
