Question about Dell Inspiron 1501 Notebook
Keyboard Fn appears to be stuck
Hello-
I was working on my laptop and our cat unexpectedly jumped up and landed on keyboard. Now the alpha keys (u, i, o, p, j, k, l etc.) appear as numbers. They only work as alpha keys if the Fn key is pressed (the reverse of how the keys are intended). Is there a way to reset or reprogram the keys? I've tried rebooting and the Fn key still seems to be overriding these alpha keys.
thanks,
Laura
  • 659 Answers
Check to see if the num lock key is on
Posted on Nov 24, 2008
Alpha keyboard not working
if usb keyboard and local keyboard aren't working i'd check to see if you have a fuction key pressed that disables you from using the keyboard, try restarting, if it solves the issue it was a FN key if not, problems deeper and you may want to look at hardware diagnostics
Apr 17, 2013 | Acer Aspire Computers & Internet
Hello, I have a problem with my laptop. It is a Haier H51. My cat jumped on the keyboard yesterday and now my mousepad doesn't work anymore... I saw a small window in the topleft corner for a short time,...
That must be added to a newspaper headline. "Cat kills mouse pad". Sorry about that!
Usually whatever you do, keyboard wise, will be reset when you reboot.
Open control panel and select mouse. Adjust as you require.
Hope that fixes it.
Feb 25, 2011 | Computers & Internet
The keys that are alpha - numberic are typeing numbers instead of alphabet.
There should be a key marked [FN] check that key for something stuck under it. If nothing is there press the [FN] key and make sure the number lock is off and see if that corrects the problem. If it doesn't the next step would be double checking the keyboard selection inside windows and reloading the keyboard drivers finally if nothing from above corrects the problem you will need to replace the keyboard. If you have ever had that area open for maintenance or cleaning open it up again and make sure the connector hasn't come loose.
Feb 08, 2011 | IBM ThinkPad T42p PC Notebook
How do I change my keyboard back to Alpha?
Please try to turn off the Num Lock :
Press and hold Fn key and then press NumLk key at the upper right corner of the keyboard)
Then release both keys
Mar 29, 2010 | IBM ThinkPad R52 Notebook
Cat sat on laptop changed screen brightness. its to dark how do i brighten monitor
There is a master function key that you hold down while tapping another function located on the keyboard. This all depends on the model of laptop. Next time try to giva a little more info like make and model, which is located on the bottom. The function key or Fn key is usually located on the keyboard near the Alt and Control key lower left. while holding this key down, you tap the corresponding brightness key on the number of the keyboard, some times the brightness is on the 4 arrows on the right side of the keyboard...sometimes they are the numbers 6 or 7 look for what appears to be a symbol that looks like the sun or a light. Hold down Fn and tap the key that brightens the display.
Sep 05, 2009 | Computers & Internet
My cat has walked over key board of hp notebook. letter I is showing as number 5 help please Thank you CP
Hi ya
try and press and hold Fn key (on bottom left) and then press num lock key(top right) with the Fn key held. If not let me know
Regards
Diarmuid
Jun 09, 2009 | HP 530 Notebook PC
Keyboard stuck in Fn mode
had the same prob on my laptop which doesn't have a seperate number pad so all I needed to do was to press "Num lock".
Apr 04, 2008 | Balance CN6555 Notebook
I have just bought my son a laptop,i cant get connected to my live box it says the wireless is on but the light is not on also on the keyboard i have to hold the fn button down to use the letters m j k l u...
Have a look at the F keys at the top of the keypad. The fn key is a toggle key. It changes the mode to something and then back again when you press it. There will be an F key with a picture of a keyboard on it (probably) (Dont press the one with the the picture of a computer on or your screen will go off)
Press fn and the keyboard Fkey together to toggle back to alpha keyboard rather than numeric.
Mar 25, 2008 | Computers & Internet
10 key pad within the alpha keyboard
Utilize the numLK button located in the upper right area of the keyboard. Depending on the layout, you may need to press it in conjunction with the Fn or Shift key.
Good luck.
Nice laptop
Nov 01, 2007 | Toshiba Satellite M45-S169 Notebook
Dell Inspiron 1501 Notebook Logo
430 people viewed this question
Alun Cox
