Question about ViewSonic G70F 17'' Monitor + Wyse Winterm 1200LE (g70f-bun) Network Terminal
H.V. frequency over range
Trying to get Fedora Linux to run. Core 6 installed. As it boots, immediately after "starting udev:" get the message on my monitor "H.V Frequency over range" on Viewsonic G70F being fed from the VGA port on a Gigabyte S3 s series motherboard. I don't really know what is going on. Any ideas, suggestions would be appreciated. Thanks
  • m_chleng Oct 29, 2008
    My screen resolution went on maximum, and Hv frequency over range message appeared. I dont know what to do.Pls help.
I have a philips 105s5 crt monitor.First problem is vertical dead.Replaced this ic .Power ok but screen appear" H.V frequency over range" .How to solve this problem.Please suggest me.
Posted on Dec 21, 2009
  • 45 Answers
When your computer won't boot properly. check for components in your pc especially the RAM. it is that your pc have problem and not the monitor.
Posted on Jul 21, 2007
I have faced the same problem ie
"HV frequency over range"
solution
i simple restart my Pc and attach another monitor and set the resolution to 800*600 again restart my Pc and attach my own monitor on which problem was ouccured and get rid of this problem.
thanks
kashif shah
Posted on Mar 25, 2011
  • remove all the plugs of the pc and again plug it and press restart
Posted on Nov 25, 2009
Check the xorg.conf and look for the "Monitor" section, once there writte:
HorizSync 30-70
VertRefresh 50-160
This values are according to the monitor model, check the website for this values...
Posted on Oct 25, 2007
Looking for drivers to use this monitor with Fedora 20 Linux OS
You don't need drivers. You need to adjust the resolution and refresh rate. If you plug in an old CRT monitor then Linux will probably boot and you can edit the conf file to change the settings. Most LCD monitors require 50-60Hz refresh rate.
May 05, 2014 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
How to install linux fedora 7, already i am using windows 7, now i want to use dual os's , please tell me how to install linux.
WARNING: I will not be responsible for any data loss that occurs. It is recommended to backup your hard disk to external media before commencing any of these operations. 1. Download and burn the Fedora LiveCD. It is recommended that you use the latest version, Fedora 14, instead of 7, but you can use Version 7 anyways. 2. Boot up with the Fedora LiveCD. Select Install. 3. Follow the instructions displayed onscreen. When you reach the partitioning screen, you will need to resize your Windows partition. Resize it to a reasonable size (1024MB =1GB). Leave at least 5GB for Fedora to install. 4. After resizing, select the "Use Free Disk Space" option, and continue installing. 5. Your system will be installed with Fedora and the GRUB bootloader. The GRUB bootloader will allow you to boot into both Windows and Fedora.
I hope this post helps you. I appreciate your vote very much!
Mar 03, 2011 | fedora Linux Operating System
Hello, First of all, I'd like to tell you that I had installed Windows 7 (clean) on my new computer. Then, I installed Fedora 13 64-bit. Eventually, I wanted to install Windows XP, so, formatted the...
Hello there kapeel_sable
First of all, why you want to install WinXP when you already have Win7 and you can just Downgrade it to WinXP..
Best Solution for this is to Recreate partition again. Start it with Win7 (dont worry Win7x is Downgrade-able to WinXP & Upgrade-able to Ultimate, Pro.) Then your Linux box.
Use quicky option compadre...
Hope that helps...
Aug 17, 2010 | Computers & Internet
How to download and install apache on linux5
Hi Follow the below procedures.
How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same.
Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd
Now, start the Apache/httpd
# chkconfig httpd on
# /etc/init.d/httpd start
Task: Install Apache/httpd under Red Hat Enterprise Linux
# up2date httpd
Start the Apache/httpd
Task: Debian Linux httpd/Apache installation
Use apt-get command:
# apt-get install apache2
# /etc/init.d/apache2 start
Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command:
# rpm -ivh httpd*
Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
Dec 30, 2009 | Red Hat Enterprise Linux ES 3 Standard...
Windows not booting
Regarding on your problem, the main issue their is the booting problem of XP after you delete the fedora operating system. That's common problem especially when the computer are in dual boot OS then you delete the other OS. Now, the reason why it usually fall into this problem its just because the XP is your core OS then you install Linux Fedora inside in XP so whatever changes you have done in fedora particularly deleting Linux OS inside XP affects the overall performance of your XP and eventually if you delete the Fedora without proper unistallation process done by Linux OS then the Boot Loader of your XP will also corrupt or delete that's the main cause of boot failure in your XP OS. Now the best solution there is to repair your XP by inserting the XP CD Installer and boot the CD to repair your OS or you can reinstall the XP OS without formatting the storage to prevent the lost of your data that has not yet already copyed a back up.
Please do this recommendation to save and restore your XP.
thanks
Sep 04, 2009 | Microsoft Windows XP Professional for PC
Booting up fedora 10, screen has horizontal dashed lines. all of screen, including toolbar.
Incorrect Graphic Card Driver,
Incorrect (or 'out of range' ) screen resolution
Incorrect (or 'out of range') refresh rate.
Boot to shell prompt.
run xconfig
reboot.
That may or may not help.
Jan 30, 2009 | fedora Linux Operating System
How i can install linux on hp dv2519tu laptop.
i think the cd from which you are installing might have got scratched so the cdrom couldnt read some files which are needed for installation ... so i suggest you to try changing cd....
there is no problem with installing in laptops we can install linux in any laptops......
i suggest you to install fedora core instead of redhat...
fedora core has good functionality and it has inbuilt firewall security also for internet and it has got good options ... so try installing fedora core 5,6, or 7 .. if you dont have means you can download from net as linux is open source to all any1 can download from net ...
there are many other linux available like ubuntu,suse, mandrake etc....
suse linux is also very good it is the very user friendly linux ...
there other linux which can be run by cd only which doesnt need of installing it just like knoppix live cd etc....
be care ful while partitioning if you make mistake you will lose all datas ....
Feb 08, 2008 | Computers & Internet
Display driver problem
ya there is a problem with driver while installing fedora core 4 i think ... u must have also tried in that only ... so i suggest you to install other version of linux... there are many other versions available like ubuntu,mandrake,redhat. or you just give try with installing the latest version of fedora core ...( try fedora core 6 or 7)..
as linux is a open source for all you can download it from net for free.............
Nov 22, 2007 | Computers & Internet
ViewSonic G70F 17'' Monitor + Wyse Winterm 1200LE (g70f-bun) Network Terminal Logo
2,444 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
