Question about Whirlpool Duet GHW9150P Front Load Washer
What does error code 02 F mean
During a cycle I continue to get an error code 02 F. Then I press cancel and it clicks then I press start and it starts back up. I have to continue this through the cycle. Can you give me some tips on what the issue may be?
  • riedelbros Nov 25, 2008
    Is the access panel in the front of the washer or behind the washer?
    President:
  • Whirlpool Master
  • 2,651 Answers
Youll need to remove the lower accces panel, (3 screws across the bottom of unit) behind htere will be a teurn screw giving access t o the pump cleanout, possible that it is full with gunk/debris, preventing proper drainage. F 02 poor drain
Posted on Nov 22, 2008
F-20 code washerjust says f-20 what is this please Answer This...
Posted on Nov 23, 2008
This worked great for me. Everything is fixed and the washer is running great now....Thank you so much. I have a daughter with brain and spine cancer and couldnt afford to get someone out here to fix it. You save me alot of heartache. May God Bless you always for taking the time to post a solution for this problem!!
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool duet gas dryer PF error will not reset as per manuals
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Won't run
found a pf not an a fp
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
