Question about HP Officejet Pro L7590 All-in-One InkJet Printer
Blank Ink not pumping to print head
Here is the problem. I ran out of black ink in my HP L7590 AIO printer, faint black print with white streaks. Installed new printer cartridge (alas aftermarket from LDProducts... used one of their cartridges before with no problem). The printer refused to print black. Cleaned the head as per instructions several times, automatically and by hand with cleaning solution. Result is the same... First page prints ok (the black is a little light, not deep black as before), second page prints about half and then goes lighter and streakier. Finally looked at the tubes going to the printhead. All of them are full, except the black... has a nice long stretch of no ink. I tried inserting and reinserting black ink cartridge. I even opened another new cartridge and put it in. To no avail, the black ink is apparently not pumping to the print head. The other inks appear to deliver o.k. to the printhead, their tubes are full... no bubbles or empty stretches like the black line. Any suggestions on what to try next?
Cheers - Richard
  • 1 more comment
  • jramsey5 Nov 26, 2008
    I have the same problem...tried replacing the black ink cartridge and, if anything, it is worse.
  • uwe9 Nov 29, 2008
    Thanks rstar111 :-)
    I tried that twice. Went through the 20 minute routine both times. But both times it gave me the message "alignment failed"... and the black is still NOT printing :-(
    Called HP trechnical support (I hate that!) and went through a one hour gig with them. They told me to disconect power, push on/off button 25 times, hold down # and 3 key while reconnecting power. Printer went through some weird reset. They had me do the same gig while holding down # and 6 button. Then the printer came back with "Following cartridge not intended for use in this printer: Yellow"... needless to say, it never did that before... Of course HP blamed the printer malfunction on the aftermarket cartridges and asked me to first install genuine HP cartridges (Which I will do next week) and see if the problem persists. If so, I am supposed to call them back immediately with my ticket number and they will fix it... (It is still under warrenty :-)) I will keep posting the results here and let you know what happens!
  • FRAGAR Dec 08, 2008
    I have the same problem went through all the garbage with HP Support, to their credit sent me a new printer within three days.
    Problem is the new printer does the same thing, they were supposed to send a new black/yellow print head didnt happen.
    This printer is a business printer and I depend on it it has been off the air for at least a month.
    I tried to talk to a person based in Australia as all I kept getting told by offshore support is that they have stock issues with the print head, but it hasn't stopped the supply for new printers I've noticed.
    When I was finally put through toa tech in Australia I got an answering machine left message still waiting for call back.
    Pretty poor effort HP, I still have a Compaq Presario waitng for a new screen booked in 18 months ago, I think this will be the last HP product I buy its a shame their products are normally pretty good lack of customer service and back up.
    Bottom line I think your print head needs to be replaced best of luck.
    Frank
    New Friend:
    Problem Solver:
  • 5 Answers
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Posted on Nov 28, 2008
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
When you change the print heads for a Hp L7580 what problems does it resolve?
Replacing the print heads fixes any poor print quality you are experiencing. Typically people replace print heads when a certain color (most likely black) is printing very faint or streaky. Over time the nozzles in the print head can get clogged with dried up ink. Enough clogged nozzles will inhibit ink from being deposited on the page in certain areas.
Feb 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
C-7250 HP all in one appears to have a stopped up printer head?
Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK Inkypete
Apr 23, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Apr 10, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Epson CX3810 started leaving blank streaks, now no ink on page
I went to Epson.com's technology on google - and as I followed their prompts, I learned that it was the printer heads and that you aren't supposed to tilt the machine. I have been moving it a lot, so undoubtedly tilted it. You can follow the prompts after a right click on the printer icon on the bottom left corner of the monitor and it cleans the printer head. This also solves a white streak problem if people are having white streaks where there's no pringint....They had lost of answers there too.
Dec 13, 2008 | Epson Stylus CX3810 All-In-One InkJet...
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
1,503 people viewed this question
Ben Johnson
