Question about NetGear WGT624 Wireless Router
Http://www.routerlogin.net the puter won't let me get the router installed i bought a remanufacrted one it did not come with a cd
SOURCE:
  • 117 Answers
SOURCE: Good day to all. I have a problem of my NETGEARWPN824V3
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
Configuring Smart Wizard for WEP encryption:
  1. Click Start then go to All programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  2. NETGEAR Smart Wizard wireless utility should appear on your desktop screen.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless network within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit the Connect button.
  5. On the Settings tab, click WEP under the Security option then select Enter Key Manually.
    Note: If the network key consists of 10 characters, set it to 64 Bits. If the network key consists of 26 characters, set it to 128 Bits.
  6. Type the 10 or 26 characters (Hexa decimal) keys on the space provided.
  7. In the Profiles field, assign a name to help you remember this wireless network settings in the future, then click Save Profile.
  8. Click on Apply to validate the settings.
  9. Once connected wirelessly, go to About tab and check for an IP address.
Configuring Smart Wizard for WPA encryption:
  1. Click Start then go to All Programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless networks within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit Connect button.
  5. On the Settings tab, select WPA under the Security option.
  6. Type the WPA password/passphrase inside the empty field next to the WPA drop down menu.
Best of luck and have a happy and safe 4th of July weekend!
Posted on Jul 02, 2010
router-user
  • 550 Answers
SOURCE: I can't access www.routerlogin.com or
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Posted on Sep 14, 2010
  • 630 Answers
SOURCE: I am trying to install a used netgear wgr614v8
Try http://192.168.0.1 or http://192.168.1.1 username should be admin with a password of password.
To reset hold the reset button for 10 seconds
Posted on Aug 28, 2009
  • 6 Answers
SOURCE: I tried to connect Netgear Wireless Router
Try connecting a cable directly from your router to your laptop and using the actual IP address of your router instead of routerlogin.com, being a Netgear it should be 192.168.1.1 or 192.168.0.1.
Hope this helps.
Posted on Nov 13, 2009
anandg27
  • 1272 Answers
SOURCE: http://www.routerlogin.com/byconfig.htm
This is an incorrect address. Please try http://www.routerlogin.com/basicsetting.htm
This will log you to the basic setting page of the router. Just click apply and enter the username and password of the router.
Regards
Anand gupta
Posted on May 03, 2010
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
Set up cd
you do not need the cd if you use its web-based interface, open your browser to the router's IP and start making changes to the router configuration from there.
good luck
Majdi
Dec 27, 2011 | Belkin Basic Wireless Router
The cd that came with my dlink dir 300 won't work on my windows xp how do I install dlink?
Here is a link to the install wizard. The wizard is the easiest way to set it up.
Click here and save the file and then open it for setup.
ftp://ftp.dlink.com/Gateway/dir615/Apps/RouterSetup_dir615_410.exe
Jun 10, 2011 | D-Link DIR-300 Wireless Router
I am unable to install printmaster platinum 10 after taking it off my com[puter
If you're doing the installation from a cd, make sure it is not scratched. If is scratched you can get a copy from the internet. Which is okay since you already have a serial key that was bought.
Mar 25, 2011 | Broderbund PrintMaster Platinum
I have installed wbr-1310 to main puter but cannot install on lap
Make sure the wireless capabilities are turned on on your router.
On your computer scan for available networks and it should detect the router.
Once detected it will ask you for the Passkey/WEP/Secutity Key.
You should have a note of this when you originally set up your wireless connection.
If not then your computer network set up wizard may 'kick in' and just follow the instruction.
Remember to keep a note of your PASSKey/WEP as you will require it in future
Good luck
Jul 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Trying to get 2nd desktop computer to connect to router which is turned on at the main computer terminal. Was told to buy a Linksys USB adapter, which we did. Then a note came on screen saying to stop...
just plug it in it will ask for the cd run the cd and you are on | stop the auto install
the browse the cd with the driver install that pops up
go to the drivers folder on the CD
pretty simple
let me know if it works
Sep 22, 2008 | Computers & Internet
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
971 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
