Question about Samsung Televison & Video
Dimming I have a 22 inches Samsung Lcd tv. This is a gift to my child and i never used and pay attention on it. Recently I noticed my son unplug the power cord and plug it back too often. I asked him why he did that, my son told me the tv get dimmer after a while and he needs to unplug and plug again in order for the tv to work . I was shocked when my son told me this happened since the tv brand new. I have the tv for 3 years, if i have known this issue happened at the very beginning i would have returned it. Please advise as why the tv would get dimmer and turn dark after a certain period of time. Thanks so much for the help. Mag
SOURCE: Hyundai LCD TV HLT 3010 Pictue suddenly turns black but has voice
This is quite a common problem on LCD televisions.
It is not a fault you can repair yourself unless you are a competent electronics engineer.
One of the transformers on the inverter board will be the cause as the tend to go open circuit. Being surface mounted adds to the dificulty of changing this item as well.
Posted on Dec 18, 2007
SOURCE: Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
Posted on Feb 29, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
SOURCE: Viewsonic N3000w LCD TV randomly shuts off...
hi,guys with shutting down viewsonic t.vs.
As you power up your t.v continously press input button on your tv
until it powers on.Sometimes last all evening,someyimes for 5 minutes.
your welcome
Posted on Dec 01, 2009
I have a 65 inch Samsung LCD. 5 years old. Recently if tv is on for over an hour and I turned it off. It won't turn on unless I unplug TV.
If its a LCD set and over 6 yrs old made by Samsung it would might some Cap-xon capacitors in the power supply that were prone to failure, replace the PS board or you could repair it yourself for under $5.00 if your handy with a solder iron and have some general electronic skills...Good luck
Nov 18, 2017 | Samsung Televison & Video
Lightening strike on samsung TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 20, 2014 | Samsung UN55D7000 55 in. 3D LCD TV
My samsung un22d5000 flashes the power light 6 times and then goes dark and will not turn on
This is an indication of protection error and might require attention of a qualified service technician.
Aug 11, 2012 | Samsung 22 UN22D5000 22 LCD TV
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
I have a 15 inch samsung lcd tv model ltn1565s or rb15ns tv.many times i have to unplug the tv for half hour to get it to restart.the power light will blink about 25 times when it wont come on. any...
UNPLUG take the back off and you will notice 3 to 7 capacitors on power supply swollen and/or cracked. Replace with same values and make sure the replacements are 105 degree capacitors so youll have longevity in the repair.....
Hope this gets ya running again: SAM FARRELL
Feb 17, 2011 | Samsung Televison & Video
When i turn my monitor on it shows no picture and it makes a sound like it is running the electricty went out and when it came back on thats when the trouble started thank you
It's time to spend $100 to buy a brand-new 19-inch LCD monitor,
or $200 to buy a brand-new 22-inch LCD monitor,
rather than paying a TV/CRT technician $50 to $75 per hour to try to fix the "antique" monitor.
Aug 05, 2010 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
Can not turn off power lock
hold volume up and menu buttons at same time for 10 seconds - under left edge of tv
Jun 15, 2009 | ViewSonic N2230w 22 in. LCD TV
Samsung LCD TV series 5 240Vac, 50Hz will it work with 60Hz?
no only the voltage is critical.the only point is you have to select right counrty and tv sound and picture system on setup menu!
Jun 11, 2009 | Samsung LT-P227W 22 in. HD-Ready LCD...
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
