Question about Gateway Computers & Internet
How to open case on E series - Gateway Computers & Internet
  • 749 Answers
This should get ya going in the right direction, go here http://support.gateway.com/support/manlib/Desktops/desktop.shtml , pick your case style, download the manuals . it should be in there. i would find out for you but you have not included your model number in this post.
Regards.
Posted on Nov 22, 2008
Http go acer com id 17883
You want to open physically or open it virtually? physically you open your computer case and locate hard drive at hard drive bay. to open virtually you need to locate my computer and open it from there.
Aug 06, 2014 | Acer Aspire AS5252-V333 Laptop with AMD...
1991 BMW 850 SERIES DOOR LOCK CLICKS CONTINUOUSLY IN COLD WEATHER AND WILL NOT OPEN THE DOOR WHEN USING THE KEY.
Cold weather affects it because the resistance in the doorlock-motor windings increases to the point not enough voltage gets through to be able to open the latch! Replacing the doorlock is the only sure fix in this case as they're not serviceable!
Oct 08, 2010 | 1991 BMW 8 Series
I need Guidance on opening the case up to check/replace battery. This is a Remington WPG-250 and doesn't have any screws on the outside.
There are no screws holding this together only 8 locking plastic clipbs (4 on each side). To open I started near the battery charger end and used a flat tip screwdriver to gently pry open the case. Repeat on the other side. Unit has 2 Sanyo NIMH AAA batteries (welded tabs in series). I can't determine if these are regular NIMHs or enloops.
Aug 22, 2010 | Remington WPG-250 Hair Trimmer
Lenovo 3000 C Series, my cd slipped inside of the computer, I took the screws from the back, and I still can't get it open.
Here's the manual.
http://static.tigerdirect.com/pdf/Lenovo-3000-J110-7393-PC-Hardware-Guide.pdf
Page 91 shows how to get it open. Two thumb screws on the back, then slide off the side of the case.
Hope this helps! Please leave a rating!
Mar 11, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
Open the case of a Sony VAIO PCG 6L7P
There are a couple removable panels on the bottom cover.Open them 1 at a time and your HDD should be in there.You'll need to unscrew the mounting bracket then pull the drive away from the attached end and then out.
Good or bad,please rate my post?
Bob
Feb 24, 2009 | Sony (B99860307) for VAIO PCG-K series...
Button worn and stuck
There are a series of molded plastic "hooks" on the top & bottom case running along the handle seam. Once you get the 6 bottom screws out, carefully (!) work a large flat-blade screwdriver between the case halves as it opens, working toward the handle. With careful application of pressure, the handle seam will pop apart. These hooks were only in the very first from production Carousel 4xxx & 5xxx and the Ektagraphic III series. Now you know why they were removed - - it's a pain to get the projector open !!!
Dec 09, 2008 | Kodak Carousel 4600 Slide Projector
Computers & Internet Logo
332 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
