Question about Olevia LT27HVX 27 in. LCD Television
Says no signal when switched to hdmi when there is one.
I just hooked an hmdi cable to me tv from my cable box. When I swith to the hdmi input it says no signal when I can clearly see the picture coming from my cable box and then after a few seconds it just turns to black. Anyone have any idea what is happening?
  • 1 more comment
  • Punky234 Dec 14, 2007
    I have the olevia 27in and bought the Toshiba HD-A3 DVD player a month ago. I hooked the HD DVD player to the tv via the HDMI input and it worked great for about two weeks. I took the DVD player to my parent's house and hooked it up to their Sony 50in to show them the picture quality and when I hooked it back up to my Olevia TV, the HDMI source would not produce a signal. I have a monster hdmi cable and it works fine, but now whenever I switch the source to the HDMI input and turn the DVD player on, it just says "no signal." I got it to work once in the past few weeks, but I have no idea how it came on. I was just unplugging it and turning it on and off and playing with the TV setup options and it came on, but then when I tried to turn it on again, it said "no signal." What should I do? I feel like my TV is broken....
  • Anonymous May 18, 2008
    i cant remove my stand on my olevia model number 232-s12 how do i do so
  • Anonymous Jul 21, 2008
    no signal when on HDMI
    Problem Solver:
  • 5 Answers
My best guess would be that the resolution settings on your reciever are set too high(It's putting out an HD signal the TV can't display) Plug in through Composite or component the the box and resolve this through you Cable box's menu, then reconnect the HDMI cable.
Posted on Jul 18, 2007
Hmdi to rac
No. HDMI cables use the RGB and sync on separate connection pins on the cable. RCA cables use the whole composite picture TV signal on the cable.
Jul 29, 2016 | Video Game Consoles & Games
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
How do i hook a bluray player up only with hmdi cable to a older tv without hmdi hookup?
Just buy an HDMI to AV converter box. It will converter the HDMI to Composite video. If your TV have Component video input then its better to buy HDMI to Component video cable. component video quality is better than composite. Its have resolution up to 1080i.
Electronics Equipment Repair Center
Oct 06, 2014 | Sanyo Televison & Video
What channel does the tv need to be on for the hmdi cable to get a signal?
It's not a channel. You should select the input to TV to HDMI. Refer its user manual, please.
Electro help
Sep 21, 2014 | GPX KCL8807DT TV/DVD Combo
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
Feb 05, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
How do you hook hmdi cable up to Mitsubishi hdtv wd62528?
Must select correct input, on your model the input used is not "labeled" HDMI, look in your user manual.
Feb 16, 2012 | Mitsubishi Televison & Video
Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
Dec 19, 2009 | Computers & Internet
No signal
Try changing the order you turn on your TV and cable box, don't switch both together. The TV will likely skip the HDMI inputs if there is no signal there. Alternative you can change the TV's source after the cable box is on and that should allow it to not skip the HDMIs. You don't have HDMI to DVI adapter(s) in the line, do you? -Ken
Jul 30, 2009 | Televison & Video
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
Olevia LT27HVX 27 in. LCD Television Logo
679 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
