Question about Microsoft Xbox 360 Controller
Controller all of a sudden will not turn on for more than 1 sec.
One day I go to turn my controller on and it does not work so I try again and it still does not work so I think that it is the battery pack . Later the next day I found out by switching the battery packs that it is not the battery pack . Now today I think that the problem is inside of the controller .I would like to know what the problem really is.
P.S.
I do not believe that I nor anybody else had thrown or dropped my controller from an unsafe distance .
From, Da Bea$t
  • sgriffin6940 Nov 22, 2008
    i have the same problem i pushed the x on the controller and it just flashis
Did u try puttin in new batteries? if ya have not there is your answer
Posted on Nov 22, 2008
How can i resolve the error code of E002-0000 on IR 2202? when ...
E002-0000 The temperature of the fixing film is as follows:
has exceeded 100C, but does not reach 115C within 1 sec thereafter. has exceeded 140C, but does not reach 150C within 1 sec thereafter. has exceeded 160C, but does not reach 165C within 1 sec thereafter The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR. 1. State Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate? NO: See "The fixing heater fails to operate." 2. Wiring Is the wiring from the DC controller PCB to the fixing film unit normal? NO: Correct the wiring. 3. Fixing film unit, DC controller PCB Try replacing the fixing film unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Jan 13, 2015 | Office Equipment & Supplies
PS3 won't reset
are you trying to get to the safe mode menu?...if so unplug for 1 minute...replug...hold power button (beep) 5 secs next beep is 1...next beep is 2 after 5 secs and power off. let go of button...repush power button(hold)...(beep)...then beep again after 5 secs...then 2 fast beeps...let go of power button. it will ask you to connect your USB to your controller then push the PS button on your controller. you should be in the menu for safe mode.(research your options there thru sony and understand what they are first before running them!)
Nov 18, 2013 | Sony Playstation 3 (PS3) Console
I cant use my controler because the green part keeps bliking and wont turn on so i cant play my xbox 360
I had this exact same issue the other day. Changing the batteries did not work for me, but don't cross that off of the list quite yet. This worked for me:
1.) Pop the battery pack off of the controller. This is the only way you're going to be able to turn it off. Wait about 5 seconds and put the battery pack back into the controller.
2.) Turn on your X-Box with the power button ON THE CONSOLE. It should turn ON. If it doesn't, unplug the X-Box for 30 seconds, plug it back in, and try again.
3.) When your X-Box turns on, go ahead and hit the controller's power button. Things should function normally from this point forward.
Please let me know if this works for you!
Sep 30, 2011 | Microsoft Xbox 360 Controller
How to resolve e00002-0000
E002
The main thermistor (TH1) has poor contact or an open circuit. The thermal
switch has an open circuit (TP1). The fixing heater has an open circuit. The
AC driver PCB is faulty. The DC controller PCB is faulty. The door switch
is faulty.
E002
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause: The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact,
Caution: To clear the error, execute the following in service mode:
Action See the description for E003.
E003
Action
1. State
2. Wiring
YES: End.
Feb 12, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Have second wireless controller xbox 360 does not recognize it .shows up as second person on screen then days plug in controller. never activates
if you have some sort of cable with which you can connect your controller to your console, it is best you try use it.
if you don't, here is what you would do.
1.switch off the console and all it's controllers.
2.differentiate between the two controllers.maybe tag them controller a and b
3.turn on the console again and switch on controller a first, wait and see if it synchronizes properly.
4.turn off controller a and switch on controller b and see if it synchronizes with your console properly.
5.if they both work separately, turn everything off and switch on again and try to use both controllers at the same time.
6.if it repeats the same thing, switch only one controller on and then when you turn on the other one, press the small button in front of the controller close to the right trigger button and also press a button that looks similar to it on the console. this should help you synchronize all the controllers.
Dec 29, 2010 | Microsoft Xbox 360 Elite Console
I was playing music off PS3 HDD when we had a power cut for approx 0.5sec. Surge/spike protecter was fitted to power source, but no power back up was fitted. Error msg was on screen saying to turn off PS3...
This is a processor error. There is no way to get to the restore screen when you have the yellow light issue. Try CPR in NYC. They usually have a 1-3 day turnaround time, and are pretty cost effective. You can easily ship them your unit. They are faster and cheaper than Sony!
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
2003 Ford Taurus SES wont start and theft light blinking
most likely the fuel pump has failed, have the fuel pressure tested.
Jun 30, 2009 | 2001 Ford Taurus
Ps3 controller
everytime you play the Ps3 and you try to play a game it loads and you have to press the PS3 button again.
click the Thank me Button XD
I helped all i can
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
Lights Flashing On Xbox 360 Controller
So the sytem is working but the controller isn't connecting? Try fresh batteries, try removing things that might interfere with the controller (cell phones, large metal things between the controller and the xbox, portable house phones, bluetooth devices), try another controller if possible (borrow one).
Jan 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
76 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
