I cant connect computer with LAN cable and also wireless is not working. After restarting comuter always appear ''please install ATKO0100 driver"
I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing ASUS drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues. Regards!
Get onlineand got to www.google.com In the google search box type: "ASUSSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers.
SOURCE: satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
SOURCE: install ATK0100 driver first
You will need to install the update first, I found 3 versions of ATK0100. You can try all versions if you like starting with the latest version. Just remember to create a restore point before you install any of the drivers that you want to upgrade just in case anything goes wrong, you can go back to an earlier time when the system is working OK.
Latest Version :
Asus ATK0100 ACPI Utility 1043.2.15.61
Link :
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Asus-ATK0100-ACPI-Utility-104321561.shtml
Older Versions :
ATK0100 ACPI UTILITY v 1043.2.15.56
Link :
http://www.techspot.com/drivers/driver/file/information/7257/
ATK0100 ACPI UTILITY v 1043.2.15.49
Link :
http://modrv.com/other_devices/asus/2869prog.html
Note : If the links will not work, jsut copy the link and paste it to your web brower's address bar.
**For creating restore point, you can just go start>all programs>accessories>system tools> System restore. Just choose create a restore point and specify a restore name.
**The Drivers that are available are for Windows XP
SOURCE: Lan connection has disappeared from network but wireless works
Have you run the Dell Diagnostics test? reboot the computer and hit the F12 key, scroll down to the diagnostic option and run the test, it will check hardware and memory etc.
SOURCE: Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
