Master does not cut
There seems to be a problem with the cutter...but the cutter seems to be ok
  • 1 more comment
  • paul nowicki May 11, 2010
    do you get a code?
  • Inbar Gross May 11, 2010
    clarify the problem please... what exactly does the machine do?
  • Greg Baird May 11, 2010
    what make and model ?
  • 76 Answers
On your drum is a long black strip,clean it with spiritis and insite the machine under the master removal unit is a black sensor. Clean that with a dry cloth. That will do it.
Posted on Oct 08, 2009
Im having trouble with my Andis Master clippers. I tried doing a cut with a 1 1/2 and they wont cut. If I use just a one or any other size they are fine, only when I raise it to a half they don't cut.
get a small shallow dish and put in a small amount of kerosene
turn the clippers on and place the cutter blades( just the cutter blades ) in the kerosene so that any gunk , hair etc is washed out
change the cutter head to a newly sharpened set
Mar 10, 2017 | Andis Health & Beauty
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
My chain seems sharp, I have filed it, but it only seems to cut if I twist it slightly to the right. Then it cuts in a banana fashion. Any ideas.m
Check that all the cutters are the same lenght, if one side is longer than the other it will never cut in a staraight line as the longer cutters will hit the timber first, als check the depth gauges are all set at 25 thou.
May 16, 2012 | Garden
No pilot ignition, air is ok
Some times when I use my plazma cutter its a cut master 42 .I would some times have to turn it off and turn it back on for it to work .And here lately all it does is air come on and off its like its has a heart beat and then have to cut it off again . I have replaced the tips and electrodes .And nothing .I have took thee electrode out and clean the white dust build up and works fine for a little while
Feb 01, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 | Garden
Problems with Lincoln LINCOLN ELECTRIC K1756-1 PRO-CUT 25 PLASMA: all settings ok, air ok will spark on occassion and then nothing. tried everything put will only lit very seldom and then nothing.????...
Try using fine sand paper and clean the tip of electrode and the thing that looks like thimble, another solution was don't tighten tip cover too much back off a little til you ge good contact. some units don't like to be clicked ON without making contact with working metal, you may get two or three clicks and then nothing til the air stops flowing.
Feb 03, 2010 | Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA...
Gestetner 5308bt copy printer error after switching on E-01 call service - How can I fix it I am on a ship at present
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Nov 13, 2009 | Gestetner Office Equipment & Supplies
Plasma cutter
in order to cut the thicker steel just boost the air pressure this will allow you to thourghly blow through the steel. just remember not to turn it up too much. this should do the trick. please rate
Sep 15, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
49 people viewed this question
jasbo
jasbo
