Question about Sony Handycam DCR-TRV17 Mini DV Digital Camcorder
Gray bars on screen during video playback
When I playback recorded video, the pictures pays, but there are 4 or 5 gray horizontal bars covering portions of the screen.
    Scholar:
  • 116 Answers
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Posted on Sep 22, 2009
Gray bars during playback. sound comes in and out
Fast forward or insert another tape. Then record something for 15-30 seconds. Then try your playback again. Worked for us.
Feb 05, 2010 | Canon ZR200 Mini DV Digital Camcorder
Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Sep 08, 2009 | Canon ZR200 Mini DV Digital Camcorder
Black screen in REC mode, bars across the screen in Playback mode
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Jul 20, 2009 | Canon ZR80 Mini DV Digital Camcorder
Gray horizontal lines in playback mode
Gray horizontal lines across the screen in playback is symptom of dirty / clogged video head and you need to use good quality mini-dv video head cleaning tape to clean video head.
Mar 16, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Gray lines across video screen during playback
my canon zr 200 in playback is fine but when i turn it on to record i have multi colored bars on screen and wont record
Jan 06, 2008 | Canon ZR200 Mini DV Digital Camcorder
Horizontal lines on playback screen
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Horizontal bars on playback plus sometimes no recorded picture
Not a solution sorry, but just to note that I have the same problem on TRV30e. It's intermittant an relatively rare, so haven't bothered getting it fixed. Seems related to certain types of DV tapes - if I change tape the problem often goes away.
Oct 28, 2007 | Sony Handycam DCR-TRV30E Mini DV Digital...
Sony Handycam DCR-TRV17 Mini DV Digital Camcorder Logo
307 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
