Question about Maytag MSD2756GES Side by Side Refrigerator
Defroster problems my defroster heating element is not heating and my coils are froze over. I talked to a tech who said I can jump a couple wires and put it into a test mode the only problem is I can not find how to get to circiut board. I took the panels off in the feezer and seen the temp sensor. so I need to know how to get to the board and also does the heating element use 120vac on both legs to heat or is it 120vac on one leg and the board sends a ground on the other? also the temp sensor on the line how does that work? opens when too cold? opens if temp of heater gets to hot? thanks
  • 1 more comment
  • thomas  perusi
    thomas perusi Dec 24, 2006
    thanks catriver, I did find the board thanks to you and I did jumper the L1 and test and nothing happened. I ohmed out the heater coil and it checked good and I also jumpered 115vac to it and verified my heater element is good. Im a little confused on how the circuit actually works. does the thermostadt in the freezer(clips onto the evaporator coil) does this get less resistance with cold and will turn on the defrost cycle.I was getting 115 vac on the wh/blk wire and Im assuming that when the board is working it sends a neutral to the yellow wires?I know my board must be bad but knowing how it works seems to be my biggest problem. oh and when I removed the covers from the freezer section the can came out with it does the fan point up to blow air away from the condenser or down on the condenser. I must have put it in wrong because my fridge is not getting cold now, freezer works great(less the defroster until I get the part) thanks
  • thomas  perusi
    after rereading what you wrote are you saying the bimetal is the part that snaps to the condenser line. I see where it says it should read 240k ohms and it does(is this concidered open(hi resistance)? sorry late at night and was not a good day.
  • daniel daoud Oct 10, 2011
    How did you find this board that apparently no one can get to? I took apart most of the temperature control section and cant locate this infamous board. Please advise.
Posted on Oct 10, 2011
    President:
  • 878 Answers
Tduck, what the tech was refering to is the adaptive defrost board. This is a common failure on these models. You are going to find it in the refrigerator side. Remove the temp control end knobs from the controllers. Remove the screws holding the light shield. Now in the back on each side you will see a tab that pushes in and the cover will pull straight out. This sometimes can be difficult task, those tabs are a real pain. Now you will remove the screws holding the defrost timer cover and the defrost timer will be in the back on the right side. On this defrost board you will see L1 and test right next to eachother. Using a small screw driver short across these terminals with the harness on. This will put the refrigerator into the defrost. If it goes into defrost and jumps right back out, you know it's the defrost board. The defrost bi-metal will be normally closed and open to terminate the defrost. So if your evaporator is warm, it will not go into defrost. You should be able to get a breakdown of this at Sears.com, go to appliance parts and enter your model number. Usually the adaptive defrost board is the culprit, I don't see too many heaters or bi-metals (defrost terminators) go bad. Your part number for the board is 61003990 for series 10. See if your serial number starts with 10.....Catriver..post back.
Posted on Dec 24, 2006
Ge TFX24S refrigerator does not get cold enough
Your Defrost electrical element (heater) is blown, you will need to buy a new defrost heater. Your evaporator coils in your freezer section is froze up (no air flow)...soild ice, thus you're not cooling down properly. You will need to defrost and then underneath the coils you'll find the glass tube with defrost heating element...you will need to replace this part (entire glass heating element)...it's DIY fairly easy to get at.
Nov 17, 2013 | GE Refrigerators
Maytag mzd2665he side by side coils inside freezer have ice build up
The defrost relay may be the problem,it also coud be the defrost heating element,you will have to remove the back panel inside the freezer side and do a continuity check on heating element if that has continuity then element is good,then the relay which is located on the wiring loop to defrost element is probably bad.locate a replacemant part and replace relay and that should solve the ice on the coils.
Jun 20, 2011 | Maytag Refrigerators
Refrigerator quit cooling. so I took the panal off inside the freezer and the coils were completely froze up.. defrosted and trying again. what would cause the freeze up?
HI. There are two causes here, in this situation. The most common will be a faulty defrost timer, or adaptive defrost control board. The defrost mechanism will vary form unit to unit. Most newer units will be equipped with an defrost control board. This will be located in the control housing, just above the heat shield, in the upper right had side. Older models will have a standard defrost timer mechanism. If this device fails, the evaporator heater Assembly will not receive the command to defrost the coil, on time. The easiest way to isolate the cause, will be to test the heater element. If the element is functional, the defrost timer/board, will eb the culprit.
Defrost heater assembly test procedure:
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice-maker and the inside rear or bottom panel of the freezer, to access.
The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky, so try not to force it, if possible. If you decide to remove it, you do so at your own risk. it will break, if forced. Warm it first with a warm towel, or hair dryer, set to low heat.
There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely faulty, and should be replaced.
Dec 05, 2009 | GE GSS20IEP Side by Side Refrigerator
Have a freezer on bottom fridge that keeps freezing where the fan is
defrost not working check defrost t-stat, timer, or heating element.
find timer and rotate till compressor turns off; defrost should start and melt ice, if no melting then check defrost t-stat ( round disc located nead heating coil) if you remove it and jump around it will begin to heat normally. If so then do not leave it jumped!!!!!!!! Replace it and you're done!!!!!!
Oct 24, 2009 | GE Refrigerators
FRIDGE AND FREEZER QUIT COOLING
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer not freezing
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Coils inside freezer keep icing up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Apr 22, 2009 | Refrigerators
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Maytag MSD2756GES Side by Side Refrigerator Logo
282 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
