Question about Hitachi Heating & Cooling
Keeps triping breaker in air con unit
Compressor gets hot
  • fvmaryjane1 Nov 22, 2008
    it is a brand new unit could it be an air lock in the water cooling system(how long would it take to over heat wit no water flow)
  • 5 Answers
I am not an a/c person, but am offerring up this one thing that I've heard.....
there are capacitors that are in the A/C unit's outside (compressors) and in the heating units (typically in the attic). If these get bad they can cause the compressors to have to work super extra hard and that can be what is causing it to get overheated - I'd be very very cautious at this point and spend the buck to have someone come out. If that is the case the compressor may already being in failure mode. We were fortunate. We caught it before ours went totally out, but for years it has been bad and has caused the compressor to work doubletime - call someone on this!
Sorry! :(
Posted on Nov 22, 2008
How do i repair my dometic air con unit on caravan
When you say safety switch do you mean fuse or breaker? If your breaker is popping(110 volt) then if probably is your compressor overloading the system.i would do as advised before and remove shroud(cover on roof) and clean coils or fins with some otc coil cleaner. Ive been in the buisness eight years and only one time have i change a compressor. Most people get a new ac. Sorry for the bad news
Dec 26, 2014 | Dometic Rooftop RV Air Conditioner
My AO35h model carriern split air con compressor triping and not cool proper same time out door fan working
Check volts and amps at the compressor, check the contactor points, make sure they are not burnt or stuck, check the run capacitor, start capacitor and relay, if you have them. Make sure the wires are good, not loose, broken, frayed or discolored from being hot. If the capacitors and relay are good or within ratings, then the compressor is probably your issue.
Sep 01, 2014 | Carrier Air Conditioner Accessories Remote...
Be sure the breaker is the right size for your unit. An under sized breaker will trip at the start. A bad compressor usually wont try to start.
Aug 28, 2014 | Heating & Cooling
Unit triping braker when compressor turns on
the breaker is underrated the power that it takes to start the compressor is really big but only for a few seconds. That is called the inrush and the breaker should be rated for HVAC wich allows for this.
Mar 15, 2011 | Fedders 9,000 BTU Electronic Portable Air...
Air con aint working its pushing out hot air not cold???
need more info have you changed thermostat lately or done anything to it... if not make sure you have checked breakers and all are good no tripped breakers... on some homes by code it is required to also have a breaker or disconnect outside next to outdoor unit make sure it is good... is your outside unit running and if so is the larger of the two copper lines cold if not and outdoor unit is running then one of two probels you either have a leak and freon has leaked out or your compressor is not starting either due to a bad capacitor or wiring on compressor may have burnt at the compressor terminals.... good luck
Jan 01, 2011 | Heating & Cooling
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
Air conditioner keeps triping breaker
has it always done this, if so sounds like you need a higher amperage sub panel to supply the unit,otherwise maybe the contactor or compressor is going bad
Jul 28, 2009 | Heating & Cooling
LG S36AHP-UD7 Split Air Con. won't turn on.
Generally when an ac trips the main breaker and the breaker its self isn't bad, the compressor is going bad or is bad. To check you will need to do an ohms test on the compressor. If you get a reading of less than infinite, then the compressor is bad. You will need to test every lead going to the compressor which is usually 3 unless you have a crank house heater installed but they are not typical on a small unit. If the compressor has gone bad it is possible the it took the board out as well.
Mar 31, 2009 | LG Heating & Cooling
Ruud Problems
compressor is probably bad. disconnect it tape the wires off and start unit. if breaker doesnt trip it is the compressor.
Aug 17, 2008 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
51 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
