When computer is started the information that loads before windows starts is scrambled. if i hit f12 and go into the BIOS everything there is scrambled too. Windows doesn't load and get blank screen. Any Sugestions? Tony
  • aaitken Nov 22, 2008
    Thanks for the reply. could be the screen has blue lines all over it.Tried to start in safe mode got to windoews options for safe mode etc, it loads the drivers and won't go any further. if i tale out the video card should the computer be able to start?
    thanks tony
  • aaitken Nov 23, 2008
    i can't even get into windows in safe mode so that is not an option. I have an 8800 GTS on a Gigabyte 965P-S3 board, if i physically remove the 8800 should windows boot and run?
    Thanks
    Tony
    Problem Solver:
  • 10 Answers
You will still need to have a PCI Express video card installed on the board in order to see what is going on as there isn't any intergraded graphics on this board. Can you get your hands on a different PCI Express card to try?
Posted on Nov 27, 2008
    Problem Solver:
  • 10 Answers
Sounds like your video driver is corrupt. Try booting to safe mode and re-install the video driver.
Posted on Nov 22, 2008
  • Cindy Welling
    Cindy Welling Nov 23, 2008
    You said it might be the monitor. First try a different monitor and if that doesn't work uninstall the driver. Please note that if you have a special video card you might need to go to the manufacture's web site and down load the latest driver. You do not have to remove the video card just the driver. Go to control panel, system properties, Hardware, device manager. click the plus sign in front of Display adapters and you will see the video driver. left click on it then right click and choose uninstall. After it uninstalls click on the action tab and choose scan for hardware changes and re-install the driver, or if you downloaded the driver install it.
I tried to reset my laptop and now I can’t have access to bios. The message I get is nibootable device-please restart the system...Itried everything
The fact that you get a message means the BIOS is working normally. If you start hitting the F2 key when you power it on the BIOS screen will load. Once there you need to make sure the proper device is selected as the boot drive. You could also try hitting the F12 key after powering on to bring up the boot menu. From there select the device you want to boot from. If you are running Windows 10 try selecting the Windows Boot Manager rather than a physical device. I've attached a clip from the user manual for your laptop and you can download it from the Toshiba web site. If this doesn't help just let me know.
Jul 22, 2018 | The Computers & Internet
How to enable disk controller in bios windows7
You can't enable the disk controller in bios, it is probably blocked. Start your computer and hit F12 until bios comes up. Under advanced settings in your bios, change your Data from AHCI to Compatibility Mode. Then restart your computer, hit the F12 button and boot from disk. Good Luck, I Hope this helped!
Feb 05, 2016 | Computers & Internet
What do I press to access the bios to reset?
Re-start the computer and well before it starts loading windows press the F2 key continuously until the screen pops up. If it does not and the computer loads and opens windows you were too late hitting the key or you were not hitting the key frequently enough. In that event you need to start the process over again by re-starting the computer again.
Dec 22, 2015 | Computers & Internet
Why is it that I am unable to boot from CD? HP Pavilion p2-1394 Windows 8.1, I would like to install Windows 7, my CD/DVD works just fine I have hit either the "F1" or "F10" keys to be taken to the BIOS...
With f8 or f9 you will get into the bootmenu it can also be esc f2 or f12, when in the bootmenu sellect dvd player then it will start from dvd it will give a line, do you want to start from dvd hit any key.
Hop that helped!
Cheers
Jan 16, 2018 | HP Computers & Internet
How to restore my laptop without a recovery disc? (acer aspire 5100)
Hi
You could try hitting the f10 key at the top of your keyboard as soon as you start the computer that should take you into factory restore to start with it looks likes its loading windows but in about a min it takes you into the option to take back to factory settings
If f10 dont work try alt\f10 or the blue fn\f10
if none of them work hit the delete key on startup and go into bios to make sure that f10 is not disabled because sometimes it is by default disabled
But be very carefull not to alter anything else in the bios or you could and probably have big problems just enable f10 0r f12 if they are disabled then hit save click yes
windows will then restart and try the f10 key again
good luck
Nov 13, 2010 | Acer Aspire 5100-5022 Notebook
When i turn on my computer a black screen pops up saying enter current password._ Unable to use f2 or f12 What am I supposeed to do
Hi
You could try to start up in safe mode ( quite often f8 ) sign in as administrator and cancel the password
Also if you get into safe mode try a system restore back to when it was ok
Or hit delete key a few times when starting up hopefully this will take you into the bios because the f12 or f2 key may be disabled
Be very careful what you change in your bios because on a laptop its not very easy to change jumpers on bios battery so only enable the f2 or f12 then hit save and exit windows will then restart
But be very very carefull not to play around in the bios if you dont understand it you may end up with BIG BIG Problems
Nov 13, 2010 | Toshiba Satellite Pro L300 Notebook
Will not load to login window
if you know that it has a recovery partition on the hdd try to reinstall the windows cause it sounds to me like a damaged windows.. to do that try to press F11 on start and see if it has a recovery partition to reinstall from ...if not try with a bootable windows disk ...
If the boot order is not set to boot from cd first and its is not asking to press any key to boot from cd ..than you should insert the disk and choose from pressing at start F12 ( or F10 ) the boot device you need..and continue the installing from the disk by pressing any key to boot from cd ..
In the other matter it seams that someone (probably the last guy that installed it ) messed around and inserted a Bios password to make sure you will call him again the next time it breaks..This matter is only avoidable by opening it and removing the Bios battery to default the Bios settings ..
Jun 28, 2010 | Compaq Presario M2000 Notebook
WINSOWS CRASHING
Ok, lets try something different,
Do you have the cds that came with your Dell. If not call up tech support on 1-800-624-9896 and request for them
Otherwise do the following steps
1. Power on the system
2.Tap on the F12 key slowly five times on the Dell logo screen
3. Select diagnostics
4.If everything passes then its good news , otherwise the faulty component is causing the crash
Part 2
1. Restart the system and again Tap on F12
2.Insert the windows xp cd
3. Select the option boot from cdrom and hit enter
4. Hit enter again when you see the message,"Press any key to boot from cd"
5.Windows starts to load
6.It will come to screen that would give you three options
a. to setup windows hit enter
b. to repair press R
c to exit exc.
7. Hit enter
8. Hit F8 on the next screen
9 On this screen it would again give you an option of repairing windows press R
10. Follow the wizard and the windows shoul start
Part 3.
If the above step fails to then the only option left is to backup your information on the system and wipe it clean .Thats a complete reset
Part 4
Restart the systen
On the Dell logo screen , hold down the CTRL key and tap on the F11 key 7 times slowly
You would see a Restore button.
Click restore and Confirm
FOllow the wizard
Caution all your information would be lost in this procedure
Thanks
Proton
Jul 17, 2008 | Dell Inspiron 8600 Notebook
Computers & Internet Logo
67 people viewed this question
Alun Cox
David Payne
David Payne
