Question about LG 42PX4DV 42 in. EDTV-Ready Plasma Television
Plasma 42inch TV
My LG 42" has started to display a breakdown of the picture after being on for 5-6hrs in a room temperature of 60-65F and 2-3 hrs at an ambient temperature of 65F and up where there is picture breakthrough behind the main picture,skin tones and scenes with white walls and similar go silvery and if left in that state for a while the screen has a lot of pixellation.If I switch to standby for 10-15 minutes then switch back on the fault has disappeared for a short while(about 1 hr) before starting again The set is less than a year old but the sellers have disappeared and LG don't have the courtesy to reply to my email.
  • Peter Searle Jan 14, 2007
    Thanks for the excellent advice as the fan cooling bit was spot on as I used the "open a window on each side of the set" trick which did work well but the temperature in the room plummetted to 44F!!!--it was during the cold snap we had a short while ago.
    I have now whinged and whined to LG and they arranged to have the set picked up last Tuesday so its now in the hands of(hopefully) repairers.
    Again thanks for your input.
    Problem Solver:
  • 8 Answers
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Posted on Jul 12, 2008
    Sergeant:
  • 308 Answers
As you may have guessed by now, the breakdown is likely being caused by a bad connection or ground. May need resoldering unless it is a semiconductor breaking down. If you can find a service center that services LG (low grade) products, I would take it there for repair. You have probably noticed a lot of heat escaping from the top of the unit after it has been on awhile. That is a big problem with plasma TV's as heat is the biggest destroyer of electronic parts that I know of (well after lightening storms). A temporary solution would be to install some fans blowing air up from the bottom back of the unit to allow it to play longer before getting too hot. Or watch less TV
Posted on Jan 14, 2007
My 42 samsung plasma tv lost picture
hello i have a 42inch plazma pdp42v6 check all caps ok
all board ok sound ok but no picture can anyone help me
fix this problem please
Dec 21, 2012 | LG RU-42PX10 42 in. HD-Ready Plasma...
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
42 plasma tv didnt dispay picture by l canhear some sound
If you are using HDMI output could be a bad or cheap cable.
I had same problem, tried another HDMI cable and all OK.
Jul 06, 2012 | LG 42LC2D 42 in. LCD HDTV
LG 42inch plasma tv suddenly lost picture, now only works intermitently. Sound is ok.
i have got the same problem with my LG 42PC1D might work for a few days or a few hours no solution as yet
Oct 25, 2009 | LG 42PC3D 42 in. Plasma Television
Hello I have a LG 42inch plasma, RT-42PX10 that has no display at all but audio is working fine. Can you please help, I've opened the back of the TV but not sure what to do. Thanks
i had a similar problem with my lg tv i went to menu/options scroll down and did a factory reset it tunes your tv in again and after that my picture came back
Dec 19, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Getting a HD Picture on MY LG Plasma
Have you made sure the box is set to send a HDTV signal to your LG? Example 720p, 1080i, or 1080p? You usually have to set the resolution in the v+.
Feb 29, 2008 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42INCH PLASMA TV BLANK SCREEN
Open the back cover and check the fuses on Y Sus Board and X Sus Board. If you can find a blown fuse, just replace that board and your problem will be fixed.
Feb 23, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
My plasma tv picture is green
take off back panel and adjust the V12(A) adjuster wheel on the power board it adjust the gas flow to the screen is should light up your screen
Sep 30, 2007 | LG MZ-42PZ14 42 in. Plasma Television
Plasma 42inch TV
I'm guessing this is a problem on the Y-SUS PCB or the Control PCB. Call LG and they will find you a servicer. Most LG Plasmas have 2 year warranties and they are covered in your home. It kinda sucks but it is better now than after your warranty expires this repair would cost several hundred dollars.
Dec 23, 2006 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42PX4DV 42 in. EDTV-Ready Plasma Television Logo
167 people viewed this question
Steve Allison
Steve Allison
