Question about Canon PIXMA MP530 All-In-One InkJet Printer
Cannot send faxes
I have set up the fax machine per the manual but am unable to sucessfully send faxes
I am unable to send a fax brother intelifax 775 fax manual
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Able to send faxes but unable to receive faxes.
You probably have to set something up in your settings.
Usually this goes: Settings>Fax Setup>Receive
Of course, this is generic, and all Fax machines are different. Is there a model number?
Jan 15, 2010 | Compaq Office Equipment & Supplies
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
Unable to enter faxes while the machine is either sending or rece
turn off
Real Time Transmission
When you are sending a fax, the machine will scan originals into memory before
sending. Then, as soon as the phone line is free, the machine will start dialing and
sending the fax. If memory becomes full, the machine will send the document in real
time (even if REAL TIME TX is set to OFF).
Sometimes you may want to send an important document immediately, without
waiting for memory transmission. You can set REAL TIME TX to ON.
1 Place the original face down in the ADF.
2 Press Menu, 2, 2, 6.
3 To change the default setting, and then
press or to select ON (or OFF) and
then press Set. Go to Step 5—OR—For
the next fax transmission only, press or to select NEXT FAX ONLY,
and then press Set.
4 For the next fax only, press or to select ON (or OFF), and then press Set.
5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
6 Enter fax number and then press Fax Start.
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Faxjet 525 will not send faxes
it is never getting a dial-tone. Phone line should be plugged into the LINE port.
Jan 28, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Trouble receiving faxes from brother personal plain paper fax 575
Press START while fax is ringing.
Try unplugging the power cord for 10 seconds.
If you do pull your hair out, please send it to me, I need more hair.
Dec 17, 2008 | Brother Office Equipment & Supplies
Unable to send & receive the Fax
Try calling your fax machine with a cell phone to see if the fax answers. If not, check that the phone wire to the fax is plugged into the LINE socket, NOT THE PHONE SOCKET on the fax machine. Next, go to the MENU on the fax.You may have to check or change one or more of the following settings by trial-and error to fix the problem. BEFORE YOU CHANGE ANY SETTING, WRITE DOWN OR PRINT OUT THE ORIGINAL SETTINGS. In the MENU, find FAX SETTINGS, FAX SET-UP, or INITIAL SETUP settings. Try changing one or more of the following: PULSE/TONE, RECEIVE MODE, SEND MODE, RING DELAY, RING TIME, OVERSEAS MODE, etc.
Nov 26, 2008 | Office Equipment & Supplies
Panasonic Panafax UF - 885 unable to send faxes direct
Hi BrendaAsh,
Thank you for the above information.
Please ask rlandriani to access the user parameters on the fax machine and turn the Quick Memory XMT to "Off" or "Invalid".
This should set the machine for direct manual sending without memory intervention.
Regards
Gavin.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax problem
Check your preference settings and make sure the fax is set to receive faxes (my friends has 6 different settings) Your manual should tell you how to do this. The default is different for many fax machines.
Jan 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
253 people viewed this question
old marine
old marine
