Question about Maytag MDE4806 Electric Dryer
Squeeky Noise Machine is 2 years old, ran fine until today... started making intermitant loud squeeking noise.
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Posted on Nov 23, 2008
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Is this a good dryer?
I bought this dryer from Lowe's May '08. No problems until today. Made a loud squeeking noise at first, now more of a ball bearing-grinding noise. Service man coming out tomorrow morning. Out of warranty, of course, paid $900.00 and not even 2 years old.
Feb 11, 2010 | Samsung DV337 Electric Dryer
Dishwaher: KUDS01DLWH3 making LOUD noises
I also had one similar to yours, and the noise kept getting worse, even after all of the normal checks. I replaced the motor/pump assembly as a unit (that's how they were sold). Online price was ~$225. This made the noise go away for about 6 months, and it came back, getting as loud as before. Instead of putting more money into it, I bought a different brand (Samsung). I ws soooo disappointed in my KA. I don't want another. The Samsung is fine....I got it on sale. Consumer Reports rates them, the Kenmores and Whirlpools pretty highly, but check their ratings for yourself; they change from year to year. I see a lot of wierd posts for Fisher Pakyl, and I'd stay away from them.
You can look for repair parts on line, and maybe your luck will be better than mine. I certainly hope so.
Best regards, --W/D--
Aug 14, 2009 | KitchenAid Dishwashers
Maytag washer performa model pavt234aww, just now 5 years old. -Two weeks ago, it started making an intermitten "loud-funky" noise, but worked just fine. Today, it filled up with water and simply died. We...
i would concentrate on moter moters have a limit not replacable , the whole moter would need to be replaced also check the lid switch this can cause a intermitant issue . as far as fixing or replacing its a issue you need to weigh out .
Aug 10, 2009 | Maytag PAV2300 Top Load Washer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Squeeky agitation (loud)
there are 4 rods that the tub hangs from. the plastic pieces at the top of the rods are supposed to wear in, but many of them continue to squeak. had the same problem with mine for the last 4 years. in year 1, the GE repair guy said this is common and showed where to lubricate. open the front panel (stick a screwdriver or stiff butter knife to depress the 2 clips.) you'll see the rods. (altho the back ones are kind of hidden). a quick spray of silicon will quiet the squeak. usually lasts about a year.
Apr 24, 2009 | GE WJRR4170E Top Load Washer
Squeeky noise while baking
If it is a fan oven then it could be a noisy fan bearing
Nov 17, 2008 | GE Ovens
Kenmore Elite model: 22932
Washing machine works fine UNTIL spin cycle. Loud engaging sound and then it makes a squeek, squeek sound...not really a squeek, but if you were to listen to it, eee, eee, eee, eee, eee and loud.
Dec 10, 2007 | Washing Machines
Maytag MDE4806 Electric Dryer Logo
320 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
