Question about Denon AVR-95 Receiver
Standby This is an older receiver. It is stuck on standby and the remote has long since disappeared. How can I get the unit off standby? It is in an open space with plenty of ventilation. Thanks.
  • Anonymous Jul 04, 2008
    crosley turntable radio cd player stuck in standby
  • Mark Reinertson Nov 26, 2008
    Same issue!
    Driving me nuts.
    Anyone have a spare remote for this as well?
4 Suggested Answers
SOURCE:
  • 54 Answers
SOURCE: Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Posted on Apr 08, 2008
  • 11 Answers
SOURCE: unit''trips'' off shortly after powering up
Disconnect ALL of the speaker wires from the back.  Turn it on again, if it still trips, then the unit needs to be repaired.  If it does not trip with no speaker wires connected, turn it back off, connect 1 speaker at a time and turn it on, when it does trip, that speaker that you just put on has a short somewhere, it could the be the wire or in the speaker.
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
Lost remote for pioneer media receiver PDP ro6g stuck on standbys how to fix until get new remote
Do a hard reset on the receiver to see if you can get it to work. Or contact Pioneer and ask for a hidden code to restore the unit to factory defaults. If nothing works you are SOL
Sep 02, 2017 | Pioneer Televison & Video
I NEED A KEY CODE FOR THE BUILT IN RADIO IN A FORD FIGO 1.4 AMBIENTE 2012 MODEL
Try this, found it on another answer board.
Press and hold the Auto button. While holding the Auto button, push and hold the Track Up button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly. Video Unlock: Use a remote from a higher end CD Receiver or any Excelon CD Receiver. Some Video remotes will work, switch on remote must be set to AUD. Press 55222277 on the remote. There will be NO visual verification when entering the override code. Head units with a Up / Down Volume control buttons: Press and hold the Volume Up button. While holding the Volume Up button, push and hold the Disp button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly.
Read more: How can I get the key code for ford figo radio systems? - Radio system key code ford figo :: Ask Me Fast at http://www.askmefast.com/How_can_I_get_the_key_code_for_ford_figo_radio_systems-qna4609185.html#q2909005
Dec 09, 2015 | Ford Cars & Trucks
Lost my remote for my RCA RT2500 Audio/Video Receiver and i cant turn it on because the power button is stuck on standby. I purchased another remote model CRK76 but it wont turn unit on. I also unplugged...
You need to confirm if the power switch is working as the button is stuck . So it is best to get this part corrected before we move to the remote as the power switch or the button aligment can be corrected if you open to check the continuity.
Next the remote controller must be checked for the IR outputs. please check this link below for tips to repair or find a link for a universal type remote.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
http://www.espares.co.uk/search/remote-controls/p/1090
Oct 06, 2011 | RCA RT2500 System
Standby light is flashing rapidly and I cannot turn on
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
Feb 27, 2011 | Marantz SR7002 6.1 Channels Receiver
Reciever keeps shutting off!
If your reciever is in a tight enclosed space, than it will overheat and shut down to protect itself. Try to get some ventilation to it by either opening the cabinet door, adding a fan, or pulling it completely out of the enclosed space.
Jan 05, 2011 | Pioneer VSX-33TX Receiver
Aug 20, 2009 | Denon AVR-1908
Kenwood ddx512
The unlock code usually only goes on if you previously put one on there. I would suggest calling Kenwood but there is a guy that claims he can fix this i have never tried this but you can. http://mike-unlockcodes.blogspot.com/
Apr 24, 2009 | Kenwood DDX-512 Car DVD Player
XV-N322 - Lock will not unlock
My problem was fixed by...having the DVD powered off, holding down the stop button on the player and hitting the power button on the remote.
Good luck!!
Jan 22, 2006 | JVC XV-N320 DVD Player
105 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
