Question about Nokia 3650
Not charging the nokia n70 phone is not charging every time i put the charger no reaction of charge what can i do im a tecnicial give me a sulution of jumper
  • 179 Answers
Check the fuse if no reacting.the place is up the charge connector.if not work check + and - make sure not korsluiting.Good luck.
Posted on Jul 02, 2010
    New Friend:
Not charging nokia2626
Posted on Apr 26, 2014
Nokia N70 no signal problem
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 10, 2013 | Nokia N70 Cellular Phone
My nokia n70 phone does not charge even with new batery. pls give me an advise.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 15, 2010 | Nokia N70 Cellular Phone
Charging problem
hi :) have your phone has been water damage ?? most after water damage,phone mother board's charging piont will be pro,tat only way u can do,pls send to mobile shop for repair it.
Jul 08, 2010 | Nokia N70 Cellular Phone
My mobile n70 not stand on charge above 3 to 4 hours
This problem is usually caused by battery but on rare conditions the charger as well. First of all, try with another battery (your friends' or..) and keep it charging for 1 hour and see the result, Second try with another charger. If the problem still persists then there might be problem with charging ic which you can't fix it if you are not a mobile technician. Give it a try and good luck..
May 05, 2010 | Nokia N70 Cellular Phone
Nokia n70 charger will not enterphone pin
Hi
Be sure that you are plugging in the right charger because some Nokia chargers are not compatible with the N70..
Also be sure that you are plugging the charger into the right port,The charging port of the N70 is the smallest hole under the phone.
Cheers
Mar 28, 2010 | Nokia N70 Cellular Phone
N70 not charging
try replacing the charger or the charging point.
Nov 17, 2009 | Nokia N70 Cellular Phone
N70 charging problem
Try changing the charger, if that doesnt work change the charging block inside the phone, you will need a T6 screwdriver... If that doesnt work, provide a bit more info...
May 07, 2009 | Nokia N70 Cellular Phone
Charging solution
what do you mean charging problem? is it the phone unit or the battery itself? try to use another battery and see what happens.
Aug 22, 2008 | Nokia N70 Cellular Phone
Nokia n70-music isn't charging...
if the unit has really a software problem, the unit OS must be formatted and reinstalled with a new copy of OS..
Aug 16, 2008 | Nokia N70 Cellular Phone
Unable to charge
if the input fix's with your phone u can charge it but it is strongly recomanded to buy a new charger...is not very expensiv and it's more safety...
Feb 07, 2008 | Nokia N70 Cellular Phone
Nokia 3650 Logo
81 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
