Question about RCA RS2650 Shelf System
Stereo locking up
2 or 3 days after i plug my system in and set the clock The stereo locks up it will not turn on and the clock is frozen at the time of the lockup. The only way i can reset it is to unplug the stereo and plug it in again and reset the clock. I have done this several times so far. The systems is brand new less than 2 months old. Any help would be appreciated.
If I were you, I would return it now. I have had every problem that everyone has mentioned on this site. It freezes up, the motor continually runs unless I open and shut the CD drawer and now my CD's don't play in it at all. I think it is a piece of junk. Sorry!
Posted on Oct 09, 2007
    Scholar:
  • 72 Answers
If you have the reciept return it to the store. There must be a hick-up in the units clock an logic circuits.
Posted on Jan 05, 2007
How do I set the time
  • Use the actual stereo to set the clock, not the remote.
  1. Turn off the stereo.
  2. Press "clock/timer" for at least 2 seconds.
  3. Press "memory" to make the hours blink.
  4. Turn the volume knob to adjust the hours.
  5. Press "memory" to make the minutes blink.
  6. Turn the volume knob to adjust the minutes.
  7. Press memory.
  8. Now the clock setting is complete.
Regards, Tony
May 21, 2011 | Sanyo AWM-660 CD Shelf System
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
No power to stereo, clock and power door locks. Is
It's simple to diagnose. Open the fuse panel, there are separate fuses for the stereo and door locks. Fuses are either good or bad.
Oct 31, 2009 | 1990 Lexus ES 250
Need to set clock
1) Press the center of the multi-control button (big round knob) once to display the settings mode which appears on the digital display of the stereo unit.
2) Turn the multi-control to until the display shows clock settings.
3) Press the control ONCE to enter this menu.
4) The display wish show the 'Hours' flashing - turn the control to adjust this setting to the correct hour and press the control once to select.
5) The "Minutes" will not be flashing - turn the control to adjust this setting to the correct minute (time) and press the control once to select.
6) Locate the "band/esc" button on the bottom left corner of the stereo face and press once to select and exit the settings.
The clock should now be set. NOTE: There are a LOT of different models of Pioneer car stereos and they will not all have the same menus. The above steps should work on the newer systems.
Sep 05, 2009 | Pioneer Car Audio & Video
Setting the clock on my damn stereo
Pioneer stereos clock setting
1)turn car iginition "ON"
2)turn stereo ON and then OFF.
3)Press SRC or Joystick until blinking clock appears
4)Set clock by pressing rt,left &top,bottom keys around volume knob (joystick).
i hope this helps.
Apr 18, 2009 | Car Audio & Video
1993 240 volvo, radio, door locks, clock do not work. not fuse.
check all your fuses,,,sometime the radio display is on a separate fuse.....
Feb 02, 2009 | 1993 Volvo 240
Complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Jan 10, 2008 | Audio Players & Recorders
Clock frozen
It certainly sounds like a defect and I believe would qualify as a warranty repair. Talk to the store where you purchased it to see what their warranty procedure is before it is out of warranty, which can be as little as 90 days. Good luck.
Nov 26, 2005 | RCA RS2650 Shelf System
RCA RS2650 Shelf System Logo
138 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
