Question about Toshiba Satellite M35X-S161 Notebook
M35x-S161. I replaced the motherboard, now video is 4/3 not 16/9
I recently replace the motherboard on my PC for the MAXIM chip problem and now the display doesn't go wide screen only 1024/768 instead of 1280/800. even on the BIOS window. Bios is 1.90 same has my original one. It leaves a 2 inches of black on the right side and 1/4 inch at the bottom. Picture is perfect beside that, just not the right size.
  • Anonymous Apr 05, 2009
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Video Controller Satellite M35X-S161
Get onlineand got to In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Video drivers.You can also try Driver Guide at:
May 06, 2012 | Toshiba Satellite M35X-S161 Notebook
I am trying to find the internal battery for the Toshiba MX35-s161 laptop. Where is it in the computer Middle/left/right?
I assume you mean for the cmos unit.
Typically they make it a real pain to get at (requires removing the motherboard from the case) it is usually located on the bottom of the mother board.
Oct 20, 2010 | Toshiba Satellite M35X-S161 Notebook
Hi, I have a toshiba m35x-s111, I was not using it for a few months because the monitor is damage. I tried starting it and now it comes on for a few seconds and then stop. Will not boot from recovery...
This is a Maxim 1987, or in some cases Maxim 1532ETL power driver chip issue. The only solution is to resolder the chip. It's a tiny chip, but very doable with a fine pin soldering iron. It takes about an hour to do the repair. The chip is next to the power plug so you will have to take the motherboard out completely to do the resolder the Maxim 1987 chip. Basically, the point is to do an actual resolder, not a reflow.
Aug 30, 2010 | Toshiba Satellite M35X-S111 Notebook
My old laptop toshiba m35x-s161 won't turn on the light on the power botton turns on and it makes some noise but nothing more happens
Sounds like there is a faulty connection between the power switch and the computer. Probably why its making a little noise.
Take in for repair and replace power button.
Jul 24, 2010 | Toshiba Satellite M35X-S161 Notebook
Toshiba Satellite M35X-S149 Turn on PS, power light lights up, fan comes on and hard drive motor is spinning, than it completely stops working after 5 seconds. Power light stays on, no other activity. Also...
had the same problem, thought my motherboard was dead as I had this issue once before and the shop the replaced the first motherboard with a bad power connention replaced the motherboard
somewhere I read that a solution was to unplug the power and remove the battery, then hold the power on button down for 30 seconds
put the power back on and try to start
well the first attempt failed but I thought, try one more time, make sure it's at least 30 seconds and my toshiba came back to life -
worth a try
Dec 05, 2009 | Toshiba Satellite M35X-S149 Notebook
Labtop will not turn back on
Toshiba won't help they are going to change the Motherboard, that will cost You big money for a later model. You need to find a tech with SMS Knowledge and tools and make him resolder the Maxim chip, is a small chip located next to power jack, this chip manage power to diferent devices, is about 1/4" by 1/4" and has 10 contact on each of the 4 sides.
Nov 24, 2009 | Toshiba Satellite M35X-S161 Notebook
I have a Toshiba Satellite M35X-S161 that will not stay turned on for longer than 15 minutes.
Check power management - clean dust from fan - full system virus/spyware/registry scan. Place external fan to help internal fan.
Apr 04, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba M35X-S161 motherboard replacement issues
How to remove back cove rof my Toshiba M35X-S161 to get the charging input jack to repair it?
Mar 28, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba Satellite M35X-S161 Notebook Logo
185 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
