Question about Kenmore 24032\24036 Top Load Washer
Agitator will not turn
When I remove the top cap off the agitator, the center bolt head on top is turning but the white agitator portion stays in one place...is there a gear of some sort at the bottom that could be stripped? Can I pull off the entire agitator?
  • cremr6 Nov 26, 2008
    I know that I have to replace the aggitator dogs, I just don't know how to get the aggitator apart to replace the dogs!
    Sergeant:
    Champion:
  • 291 Answers
Yes ,,, they are called agit dogs ,,,,, replace and that will fix it
Posted on Nov 24, 2008
Need to remove the tub on Kenmore Series 60 Washer to clean it. How do I get the agitator out?
To replace the Agitator & Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa!!
Aug 04, 2011 | Washing Machines
Tip
Replacing Agitator Dogs
The following advice is for replacing the Agitator Dogs on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10.
The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are Agitator Dogs? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
Agitator won't move
Thes units have litlle plastic dogs that make the agitator agitate, and when they break it will stop.
Remove the agitator and inside there are 3 to 4 plastic dogs or ears and these are more than likely bad.
Pry the agitator cap off by inserting a screwdriver into the cap's notch
2) Pull the inner cap (if present) off - many Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator (earlier models used a 7/16" hex-head steel bolt)
On older models, grasp the bottom portion of the agitator and pull the entire assembly out of the washer. (Some recent models allow just the top portion's removal to access these 'dogs')
5) Older models - place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once just the ratchet ***'y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All '4-dog' versions use the 285770 (or #80040) kit, regardless of the cam ***'y style. (Really old agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***'y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***'y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap's rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap's o-ring too - makes it easier to snap into place)dcramer531_112.jpg
Apr 18, 2011 | Kenmore 24042 Top Load Washer
I'm preparing to replace the agitator dogs on my Whirlpool/Kirkland SAWS800JQ2. Is the plastic gasket exposed after removal of the softener dispenser merely in need of a good tug to expose the nut for...
Nov 14, 2010 | Whirlpool Washing Machines
Trying to remove the agitator from a kenmore top loader. took off agitator cap but there is no nut down inside. i see metal but nut drivers and sockets won't fit, down opening. should i just pull up on the...
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 10, 2010 | Kenmore 24972 Top Load Washer
The top agitator does not work. It seems that
This problem is generally caused both by by overloading the machine and time. The kit to repair it is called an "Agitator dog kit" and can be purchased at any parts outlet for likely less than $10.
Good Luck
Oct 03, 2009 | Kenmore Washing Machines
Top portion of agitator does not work. Is this repairable?
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 02, 2009 | Washing Machines
Our top loading washing machine does not clean whites
Jan 21, 2009 | Kenmore Washing Machines
Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Dec 31, 2008 | Kenmore Washing Machines
Kenmore Washer Model #82881110
Remove the dispenser cap by pulling it straight up. Under the dispenser cap, there may be another cap. If so, remove the center cap exposing the agitator bolt. Using a socket and ratchet remove the agitator bolt and the top half of the agitator can be lifted out as one piece. With the top portion of the agitator removed, grasp the lower agitator by the bottom flanges and pull straight up. The remaining section should lift off the center post. For a helpful illustration of what I'm talking about, go to searspartsdirect.com and type in your model number as "110.82881110". Go to the "Agitator, Basket and Tub" heading. There's an exploded view illustration of the agitator and all the components. If you require parts, all the part number and pricing information is available, as well. I hope this helps you.
PS When re-installing the agitator DO NOT over tighten the agitator bolt. This can cause damage to the agitator and create slow rotation problems. Just make sure you tighten the bolt snug, and then give it about a 1/4 turn.
Oct 09, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
99 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
