Question about Dynex 32 in. LCD Flat-Panel HDTV
No picture - 65535 shows on screen
When we start the TV, no picture shows on the screen, but #65535 shows up when you try to pick a channel.
  • 6 more comments
  • Anonymous Nov 29, 2008
    i have this exact same problem with the 42" model
  • Anonymous Jan 09, 2009
    Same issue on a 42"
  • dsnyder1974 Jan 13, 2009
    I had the same **** happen to me this morning....it's too late for the freaking warranty :( I rescanned it...my cable is coming straight from the wall...I think it's a cable issue...because hdmi 1 and 2 worked...it's just the cable w/o a cable box it gives me remote lag between the hd and digital channels
  • jascantrell Jan 28, 2009
    37" same issue.
  • miracle-1978 Mar 18, 2009
    hey i had the same problem I turned my Dynex 42 inch on and got a black screen no signal but got a message 65535 on it so I typed in that number and saw this. I went to menu like it said and did a channel scan and the tv popped back on! I was so excited to have fixed the problem before my hubby got home! Thanks for who ever figured that out... it does fix it...
  • donkeypunch1 Mar 22, 2009
    Same thing happens to my tv every week or two, to fix it i have to go in to the menu and settings and restore the settings and then do a auto channel scan and everything comes back to normal. anyone else heard of a way to fix this or do i have to call for an RMA :(
  • Anonymous Mar 28, 2014
    My insignia tv is only showing a little strip of the screen it's suppose to show one channel it's shows 4 green dashes on the left hand side of the screen what should I do
I haven't tried unplugging my 19 " Dynex (Model: DX-LCDTV19)...yet, hopefully i won't have to. but, i did run into the 65535 ÿÿÿ... thing, except my screen actually read "65535 ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ bad" and i was not able to change the channel. the "air" option under the "Air/Cable" option under the "Channel" heading of the "Menu" -phew!- did yield me about 20 channels; but it was not the ****-near hundred channels i'm used too, ****! so i did do a cable-channel-channel-scan, as forementioned by the illustrious mr/mrs Dynex100 him/herself in the post immediately prior to this one! and this fancy technique reunited me with my beautiful cable- and it feels so good! much like a mother kitten refinding her unlost baby kitten. furthermore, the "65535 ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ bad" went away...for the most part. now my screen looked as it normally would, but still read "ÿÿÿÿÿ"<--- to a much less extent, as you can plainly see, yet still obtrusive! so i powered off, waited impatiently for about three seconds, and then slapped the ole **** tube right back on. the weak and merciful "ÿÿÿÿÿ" blip had miraculously vanished into thin-digital-cable-air! i then went on to taunt the puny-little circumvented "ÿÿÿÿÿ" blip by literally programming the sleep timer to do its thing in precisely 5 mins. the 5 mins. ticked away, and my radiation king 5000 turned off on cue. without hesitation, i lept from my wheelchair and brought power back into my 19" Dynex (Model: DX-LCDTV19) by putting it into "On" mode. this exact sequence of crazy manuvers must have really intimidated the "ÿÿÿÿÿ" blip, 'cuz he ain't been 'round since! hope this helps someone.........................................somewhere.
Posted on Feb 17, 2009
  • 4 Answers
My 42" Dynex just did the same thing. 65535 NO SIGNAL.
The channel label for this said "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"
I went to menu... Channels .... Set for Cable TV... Scan Channels.
It rescanned. It took twice as long as normal to scan.
After the scan completed it worked fine except of one thing.
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ stuck on the screen.
I shut the TV off, then things returned to normal.
Hope this helps.
Notes:
This TV is only 6 weeks old.
Cable hook up.
It is -plugged into a brand new UPS power supply.
I used the sleep timer to shut off TV. The 65535 problem occured the next time the TV was powered up.
Posted on Dec 04, 2008
Try plugging the tv in without the CATV cable, that worked for me and was able to get into menu and have it reset for all the QAM channels
Posted on Jan 21, 2009
    New Friend:
My grandfather's RCA Flat screen 28'' is connected to Bell currently. When he turns on the RCA and goes into the guide channels, nothing shows up on the channel names and it says " Channel 65535" in the channel box. Please note this RCA 28" is 1 year in use.
Posted on May 24, 2014
Proline LVD TV and DVD player problem. Hi, I can't get a picture using the RF option. I'm not sure what input I should select for this but I've tried them all and no joy in seeing the sky picture from the...
Hi Greg, i think your missing something simple.
Pick a channel number you want the Sky on, then in the tv set up
manually tune that channel to 68, or if it's showing lots of numbers for the frequency then just search towards the end and it should pick up. On the Sky box leave a menu showing so it's easier to spot when it gets to picking it up.
Nov 10, 2014 | Televison & Video
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
No channels
I had the same problem and end up unplugging the power, replugginging and then had to reprogram all of the chanels using the auto program. I still ahve a yy> show uo in the middle of the right had side of the screen when changing channel -- do not know why this happens -- good luck
Dec 14, 2009 | Dynex DX-LCD37 TV
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Channel search: skips chanels
If you have a cable box connected, it's synch circuits are bad. If your TV has a selection for HRC/ IRC make sure you know which one cable company is using .
Apr 15, 2017 | Polaroid FLM-1911 19 in. LCD Television
32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Dec 18, 2008 | LG 32LC7D Television
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Problems with the picture on my tv. Pink lines across its screen
take the back of the television and atthr back of the screen there is a sucker that sits on the back of t give it a tap and the pink goes away
Oct 15, 2006 | Sony KV-32FX20U 32" TV
Dynex 32 in. LCD Flat-Panel HDTV Logo
2,109 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
